Whenever I switch to the librenms user the default shell is obnoxious. I can’t scroll up in history or do any common conveniences. So I was thinking of switching the user’s shell to bash.
Is there any problem that could cause?
I’m pretty sure the default install instructions set the shell to bash.
So, yeah, you should swap it ![]()
Thanks @murrant ! Just wanted to be safe ![]()
