APC network management card with environmental monitoring
Let me preface this request for help with a I am NEW to LibreNMS and Linux. I have been able to setup monitoring and oxidized for my Mikrotik and Netonix switches and they seem to be working perfect! I recently purchased a network monitor card for the UPS in my NOC so that I can set up alerts if temp gets too high. I have added the device into LNMS, it discovers the sensor and names it, but never reports a temp. Searching through support here noted that the the APC needed to be in Celsius. I made sure that was the case! Internal temp seems to be working from the management card, but not from the probe. When I log directly into the UPS the sensor is showing temp and humidity just fine.
I am using SNMPv3 currently but had the same results when using v1
Any help you all can provide would be great!
WISP detected! Glad you are enjoying LibreNMS.
Check the snmp output to verify the sensor is in the output. It might be that probes use a different OID that LibreNMS doesn’t know about yet. You can check what oids LibreNMS uses by running the poller with the -d option or under capture debug in the device menu.
WISP… what was the dead giveaway, Mikrotik or Netonix?
Here is what the poller sees, it is all jibberish to me:
SQL[select `migration` from `migrations` order by `id` desc limit 1 [] 1.14ms]
SQL[select count(*) as aggregate from `migrations` limit 1 [] 1.21ms]
SQL[select version() [] 0.4ms]
Version info:
Commit SHA: 34de9dd77df4bf7bb3f30c89c93cb86620f8b780
Commit Date: 1631578375
DB Schema: 2021_08_26_093522_config_value_to_medium_text (217)
PHP: 7.4.3
MySQL: 10.3.31-MariaDB-0ubuntu0.20.04.1
RRDTool: 1.7.2
SNMP: NET-SNMP 5.8
Updating os_def.cache
Starting polling run:
SQL[SELECT * FROM `devices` WHERE `disabled` = 0 AND `hostname` = '10.10.1.6' ORDER BY `device_id` ASC [] 0.95ms]
SQL[select * from `devices` where `device_id` = ? limit 1 [12] 0.48ms]
SQL[select * from `devices_attribs` where `devices_attribs`.`device_id` = ? and `devices_attribs`.`device_id` is not null [12] 0.25ms]
Attempting to initialize OS: apc
OS initialized: LibreNMS\OS\Apc
Hostname:    10.10.1.6
Device ID:   12
OS:          apc
SQL[select `hostname`, `overwrite_ip` from `devices` where `hostname` = ? limit 1 ["10.10.1.6"] 0.87ms]
[FPING] '/usr/bin/fping' '-e' '-q' '-c' '3' '-p' '500' '-t' '500' '10.10.1.6'
response:  {"xmt":3,"rcv":3,"loss":0,"min":1.17,"max":1.36,"avg":1.24,"dup":0,"exitcode":0}
SQL[select `device_groups`.*, `device_group_device`.`device_id` as `pivot_device_id`, `device_group_device`.`device_group_id` as `pivot_device_group_id` from `device_groups` inner join `device_group_device` on `device_groups`.`id` = `device_group_device`.`device_group_id` where `device_group_device`.`device_id` = ? [12] 0.39ms]
SQL[select * from `locations` where `locations`.`id` = ? limit 1 [2] 0.3ms]
SQL[select exists(select * from `alert_schedule` where (`start` <= ? and `end` >= ? and (`recurring` = ? or (`recurring` = ? and ((time(`start`) < time(`end`) and time(`start`) <= ? and time(`end`) > ?) or (time(`start`) > time(`end`) and (time(`end`) <= ? or time(`start`) > ?))) and (`recurring_day` like ? or `recurring_day` is null)))) and (exists (select * from `devices` inner join `alert_schedulables` on `devices`.`device_id` = `alert_schedulables`.`alert_schedulable_id` where `alert_schedule`.`schedule_id` = `alert_schedulables`.`schedule_id` and `alert_schedulables`.`alert_schedulable_type` = ? and `alert_schedulables`.`alert_schedulable_id` = ?) or exists (select * from `locations` inner join `alert_schedulables` on `locations`.`id` = `alert_schedulables`.`alert_schedulable_id` where `alert_schedule`.`schedule_id` = `alert_schedulables`.`schedule_id` and `alert_schedulables`.`alert_schedulable_type` = ? and `alert_schedulables`.`alert_schedulable_id` = ?))) as `exists` ["2021-09-14T19:03:35.816235Z","2021-09-14T19:03:35.816235Z",0,1,"19:03:35","19:03:35","19:03:35","19:03:35","%","device",12,"location",2] 1.06ms]
SQL[INSERT IGNORE INTO `device_perf` (`xmt`,`rcv`,`loss`,`min`,`max`,`avg`,`device_id`,`timestamp`,`debug`)  VALUES (:xmt,:rcv,:loss,:min,:max,:avg,:device_id,NOW(),:debug) {"xmt":3,"rcv":3,"loss":0,"min":1.17,"max":1.36,"avg":1.24,"device_id":12,"debug":"[]"} 1.08ms]
SQL[UPDATE `devices` set `last_ping`=?,`last_ping_timetaken`=? WHERE device_id=? ["2021-09-14 14:03:35",1.24,12] 0.91ms]
SNMP Check response code: 0
Modules status: Global+
OS
Device
#### Load poller module core ####
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQnUt' '-m' 'SNMPv2-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'sysUpTime.0' 'sysName.0' 'sysObjectID.0' 'sysDescr.0']
.*.*.0 = 68361310
.*.*.0 = apc18A527
.*.*.0 = .*.4.1.3*
.*.*.0 = APC Web/SNMP Management Card (MB:v4.1.0 PF:v6.9.6 PN:apc_hw05_aos_696.bin AF1:v6.9.6 AN1:apc_hw05_sumx_696.bin MN:AP9631 HR:08 SN: 5A1903T32674 MD:01/15/2019) (Embedded PowerNet SNMP Agent SW v2.2 compatible)
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQnUst' '-m' 'HOST-RESOURCES-MIB:SNMP-FRAMEWORK-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'snmpEngineTime.0' 'hrSystemUptime.0']
snmpEngineTime.0 = 683613
hrSystemUptime.0 = No Such Object available on this agent at this OID
Uptime seconds: 683613
Uptime:  7 days 21 hours 53 minutes 33 seconds
>> Runtime for poller module 'core': 0.0546 seconds with 25496 bytes
>> SNMP: [2/0.05s] MySQL: [0/0.00s]
#### Unload poller module core ####
OS
Device
#### Load poller module availability ####
SQL[SELECT duration FROM availability WHERE device_id = ? [12] 0.86ms]
Availability:
SQL[SELECT * FROM availability WHERE device_id = ? [12] 0.65ms]
SQL[select * from `device_outages` where `device_id` = ? and `up_again` >= ? order by `going_down` asc [12,1631559815] 1.08ms]
SQL[UPDATE `availability` set `availability_perc`=? WHERE `availability_id` = ? [100,45] 0.72ms]
1 day : 100%
SQL[select * from `device_outages` where `device_id` = ? and `up_again` >= ? order by `going_down` asc [12,1631041415] 0.98ms]
SQL[UPDATE `availability` set `availability_perc`=? WHERE `availability_id` = ? [100,46] 0.64ms]
7 days : 100%
SQL[select * from `device_outages` where `device_id` = ? and `up_again` >= ? order by `going_down` asc [12,1629054215] 0.41ms]
SQL[UPDATE `availability` set `availability_perc`=? WHERE `availability_id` = ? [99.884,47] 0.26ms]
30 days : 99.884%
SQL[select * from `device_outages` where `device_id` = ? and `up_again` >= ? order by `going_down` asc [12,1600110215] 0.46ms]
SQL[UPDATE `availability` set `availability_perc`=? WHERE `availability_id` = ? [99.99,48] 0.3ms]
365 days : 99.99%
>> Runtime for poller module 'availability': 0.0128 seconds with 104840 bytes
>> SNMP: [0/0.00s] MySQL: [5/0.00s]
#### Unload poller module availability ####
Modules status: Global-
OS
Device
Module [ unix-agent ] disabled globally.
OS
Device
#### Load poller module os ####
Generic :(
Hardware: Smart-UPS 1500 UPS 04.1 (ID1015)
OS Version: AOS v6.9.6 / App v6.9.6
OS Features:
Serial: 3S2108X10524
>> Runtime for poller module 'os': 0.0019 seconds with 99080 bytes
>> SNMP: [0/0.00s] MySQL: [0/0.00s]
#### Unload poller module os ####
OS
Device
#### Load poller module ipmi ####
SQL[SELECT * FROM sensors WHERE device_id = ? AND poller_type='ipmi' [12] 0.62ms]
array (
>> Runtime for poller module 'ipmi': 0.0011 seconds with 2992 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.00s]
#### Unload poller module ipmi ####
OS
Device
#### Load poller module sensors ####
SQL[SELECT `sensor_class` FROM `sensors` WHERE `device_id` = ? GROUP BY `sensor_class` [12] 0.47ms]
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["charge",12] 0.5ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.2.3.1.0']
.*.4.1.3*.* = 1000
Checking (snmp) charge Battery Charge...
100 %
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["current",12] 1.74ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.4.3.4.0']
.*.4.1.3*.* = 19
Checking (snmp) current Phase 0 Output...
1.9 A
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["frequency",12] 1.63ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.3.2.4.0' '.1.3.6.1.4.1.318.1.1.1.4.2.2.0']
.*.4.1.3*.* = 60
.*.4.1.3*.* = 60
Checking (snmp) frequency Input...
Checking (snmp) frequency Output...
60 Hz
60 Hz
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["humidity",12] 1.51ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.10.2.3.2.1.6.2']
.*.4.1.3*.*.6.2 = No Such Instance currently exists at this OID
Checking (snmp) humidity Rack Temp...
0 %
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["load",12] 0.8ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.4.3.3.0']
.*.4.1.3*.* = 206
Checking (snmp) load Load(VA)...
20.6 %
SQL[UPDATE `sensors` set `sensor_current`=?,`sensor_prev`=?,`lastupdate`=NOW() WHERE `sensor_class` = ? AND `sensor_id` = ? [20.6,20.7,"load",135] 3.46ms]
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["runtime",12] 0.81ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.2.2.3.0']
.*.4.1.3*.* = 449000
Checking (snmp) runtime Runtime...
74.833333333333 Min
SQL[UPDATE `sensors` set `sensor_current`=?,`sensor_prev`=?,`lastupdate`=NOW() WHERE `sensor_class` = ? AND `sensor_id` = ? [74.83333333333333,71.2,"runtime",136] 1.11ms]
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["state",12] 1.16ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.2.2.4.0' '.1.3.6.1.4.1.318.1.1.1.4.1.1.0']
.*.4.1.3*.* = 1
.*.4.1.3*.* = 2
Checking (snmp) state UPS Battery Replacement Status...
Checking (snmp) state Output Status...
1 #
2 #
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["temperature",12] 2.19ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.2.2.2.0' '.1.3.6.1.4.1.318.1.1.10.2.3.2.1.4.2']
.*.4.1.3*.* = 25
.*.4.1.3*.*.4.2 = No Such Instance currently exists at this OID
Checking (snmp) temperature Internal Temperature...
Checking (snmp) temperature Rack Temp...
25 C
0 C
SQL[SELECT * FROM `sensors` WHERE `sensor_class` = ? AND `device_id` = ? ["voltage",12] 1.1ms]
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQnte' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' '.1.3.6.1.4.1.318.1.1.1.2.2.8.0' '.1.3.6.1.4.1.318.1.1.1.3.2.1.0' '.1.3.6.1.4.1.318.1.1.1.4.2.1.0']
.*.4.1.3*.* = 26
.*.4.1.3*.* = 124
.*.4.1.3*.* = 124
Checking (snmp) voltage Battery Bus...
Checking (snmp) voltage Input...
Checking (snmp) voltage Output...
26 V
124 V
124 V
>> Runtime for poller module 'sensors': 0.2928 seconds with 14408 bytes
>> SNMP: [9/0.27s] MySQL: [12/0.02s]
#### Unload poller module sensors ####
OS
Device
#### Load poller module processors ####
SQL[SELECT * FROM processors WHERE device_id=? [12] 0.74ms]
>> Runtime for poller module 'processors': 0.0027 seconds with 60568 bytes
#### Unload poller module processors ####
OS
Device
#### Load poller module mempools ####
SQL[select * from `mempools` where `mempools`.`device_id` = ? and `mempools`.`device_id` is not null [12] 0.44ms]
>> Runtime for poller module 'mempools': 0.0028 seconds with 77400 bytes
#### Unload poller module mempools ####
OS
Device
#### Load poller module storage ####
SQL[SELECT * FROM storage WHERE device_id = ? [12] 0.29ms]
>> Runtime for poller module 'storage': 0.0007 seconds with 2032 bytes
#### Unload poller module storage ####
OS
Device
#### Load poller module netstats ####
 ICMP
SNMP['/usr/bin/snmpbulkwalk' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'IP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'icmp']
icmpInMsgs.0 = 9405
icmpInErrors.0 = 0
icmpInDestUnreachs.0 = 0
icmpInTimeExcds.0 = 0
icmpInParmProbs.0 = 0
icmpInSrcQuenchs.0 = 0
icmpInRedirects.0 = 0
icmpInEchos.0 = 6909
icmpInEchoReps.0 = 2496
icmpInTimestamps.0 = 0
icmpInTimestampReps.0 = 0
icmpInAddrMasks.0 = 0
icmpInAddrMaskReps.0 = 0
icmpOutMsgs.0 = 9405
icmpOutErrors.0 = 0
icmpOutDestUnreachs.0 = 0
icmpOutTimeExcds.0 = 0
icmpOutParmProbs.0 = 0
icmpOutSrcQuenchs.0 = 0
icmpOutRedirects.0 = 0
icmpOutEchos.0 = 2496
icmpOutEchoReps.0 = 6909
icmpOutTimestamps.0 = 0
icmpOutTimestampReps.0 = 0
icmpOutAddrMasks.0 = 0
icmpOutAddrMaskReps.0 = 0
icmpStatsInMsgs.ipv4 = 9405
icmpStatsInMsgs.ipv6 = 0
icmpStatsInErrors.ipv4 = 0
icmpStatsInErrors.ipv6 = 0
icmpStatsOutMsgs.ipv4 = 9405
icmpStatsOutMsgs.ipv6 = 4
icmpStatsOutErrors.ipv4 = 0
icmpStatsOutErrors.ipv6 = 0
icmpMsgStatsInPkts.ipv4.0 = 2496
icmpMsgStatsInPkts.ipv4.3 = 0
icmpMsgStatsInPkts.ipv4.4 = 0
icmpMsgStatsInPkts.ipv4.5 = 0
icmpMsgStatsInPkts.ipv4.8 = 6909
icmpMsgStatsInPkts.ipv4.9 = 0
icmpMsgStatsInPkts.ipv4.10 = 0
icmpMsgStatsInPkts.ipv4.11 = 0
icmpMsgStatsInPkts.ipv4.12 = 0
icmpMsgStatsInPkts.ipv4.13 = 0
icmpMsgStatsInPkts.ipv4.14 = 0
icmpMsgStatsInPkts.ipv4.15 = 0
icmpMsgStatsInPkts.ipv4.16 = 0
icmpMsgStatsInPkts.ipv4.17 = 0
icmpMsgStatsInPkts.ipv4.18 = 0
icmpMsgStatsInPkts.ipv6.1 = 0
icmpMsgStatsInPkts.ipv6.2 = 0
icmpMsgStatsInPkts.ipv6.3 = 0
icmpMsgStatsInPkts.ipv6.4 = 0
icmpMsgStatsInPkts.ipv6.128 = 0
icmpMsgStatsInPkts.ipv6.129 = 0
icmpMsgStatsInPkts.ipv6.130 = 0
icmpMsgStatsInPkts.ipv6.131 = 0
icmpMsgStatsInPkts.ipv6.132 = 0
icmpMsgStatsInPkts.ipv6.133 = 0
icmpMsgStatsInPkts.ipv6.134 = 0
icmpMsgStatsInPkts.ipv6.135 = 0
icmpMsgStatsInPkts.ipv6.136 = 0
icmpMsgStatsInPkts.ipv6.137 = 0
icmpMsgStatsOutPkts.ipv4.0 = 6909
icmpMsgStatsOutPkts.ipv4.3 = 0
icmpMsgStatsOutPkts.ipv4.4 = 0
icmpMsgStatsOutPkts.ipv4.5 = 0
icmpMsgStatsOutPkts.ipv4.8 = 2496
icmpMsgStatsOutPkts.ipv4.9 = 0
icmpMsgStatsOutPkts.ipv4.10 = 0
icmpMsgStatsOutPkts.ipv4.11 = 0
icmpMsgStatsOutPkts.ipv4.12 = 0
icmpMsgStatsOutPkts.ipv4.13 = 0
icmpMsgStatsOutPkts.ipv4.14 = 0
icmpMsgStatsOutPkts.ipv4.15 = 0
icmpMsgStatsOutPkts.ipv4.16 = 0
icmpMsgStatsOutPkts.ipv4.17 = 0
icmpMsgStatsOutPkts.ipv4.18 = 0
icmpMsgStatsOutPkts.ipv6.1 = 0
icmpMsgStatsOutPkts.ipv6.2 = 0
icmpMsgStatsOutPkts.ipv6.3 = 0
icmpMsgStatsOutPkts.ipv6.4 = 0
icmpMsgStatsOutPkts.ipv6.128 = 0
icmpMsgStatsOutPkts.ipv6.129 = 0
icmpMsgStatsOutPkts.ipv6.130 = 0
icmpMsgStatsOutPkts.ipv6.131 = 4
icmpMsgStatsOutPkts.ipv6.132 = 0
icmpMsgStatsOutPkts.ipv6.133 = 0
icmpMsgStatsOutPkts.ipv6.134 = 0
icmpMsgStatsOutPkts.ipv6.135 = 0
icmpMsgStatsOutPkts.ipv6.136 = 0
icmpMsgStatsOutPkts.ipv6.137 = 0
 IP
SNMP['/usr/bin/snmpgetnext' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'IP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'ipForwDatagrams' 'ipInDelivers' 'ipInReceives' 'ipOutRequests' 'ipInDiscards' 'ipOutDiscards' 'ipOutNoRoutes' 'ipReasmReqds' 'ipReasmOKs' 'ipReasmFails' 'ipFragOKs' 'ipFragFails' 'ipFragCreates' 'ipInUnknownProtos' 'ipInHdrErrors' 'ipInAddrErrors']
ipForwDatagrams.0 = 0
ipInDelivers.0 = 236613
ipInReceives.0 = 236613
ipOutRequests.0 = 225596
ipInDiscards.0 = 0
ipOutDiscards.0 = 0
ipOutNoRoutes.0 = 0
ipReasmReqds.0 = 0
ipReasmOKs.0 = 0
ipReasmFails.0 = 0
ipFragOKs.0 = 0
ipFragFails.0 = 0
ipFragCreates.0 = 0
ipInUnknownProtos.0 = 0
ipInHdrErrors.0 = 0
ipInAddrErrors.0 = 0
 IP-FORWARD
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQv' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'IP-FORWARD-MIB::ipCidrRouteNumber.0']
 SNMP
SNMP['/usr/bin/snmpbulkwalk' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'SNMPv2-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'snmp']
snmpInPkts.0 = 212815
snmpOutPkts.0 = 212814
snmpInBadVersions.0 = 0
snmpInBadCommunityNames.0 = 0
snmpInBadCommunityUses.0 = 0
snmpInASNParseErrs.0 = 0
snmpInTooBigs.0 = 0
snmpInNoSuchNames.0 = 0
snmpInBadValues.0 = 0
snmpInReadOnlys.0 = 0
snmpInGenErrs.0 = 0
snmpInTotalReqVars.0 = 152838
snmpInTotalSetVars.0 = 0
snmpInGetRequests.0 = 122686
snmpInGetNexts.0 = 9111
snmpInSetRequests.0 = 0
snmpInGetResponses.0 = 0
snmpInTraps.0 = 0
snmpOutTooBigs.0 = 0
snmpOutNoSuchNames.0 = 0
snmpOutBadValues.0 = 0
snmpOutGenErrs.0 = 0
snmpOutGetRequests.0 = 0
snmpOutGetNexts.0 = 0
snmpOutSetRequests.0 = 0
snmpOutGetResponses.0 = 212816
snmpOutTraps.0 = 0
snmpEnableAuthenTraps.0 = enabled
snmpSilentDrops.0 = 0
snmpProxyDrops.0 = 0
 TCP
SNMP['/usr/bin/snmpgetnext' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'TCP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'tcpActiveOpens' 'tcpPassiveOpens' 'tcpAttemptFails' 'tcpEstabResets' 'tcpCurrEstab' 'tcpInSegs' 'tcpOutSegs' 'tcpRetransSegs' 'tcpInErrs' 'tcpOutRsts']
tcpActiveOpens.0 = 0
tcpPassiveOpens.0 = 24
tcpAttemptFails.0 = 0
tcpEstabResets.0 = 0
tcpCurrEstab.0 = 0
tcpInSegs.0 = 770
tcpOutSegs.0 = 884
tcpRetransSegs.0 = 0
tcpInErrs.0 = 0
tcpOutRsts.0 = 0
 TCPHC
SNMP['/usr/bin/snmpgetnext' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'TCP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'tcpHCInSegs.0' 'tcpHCOutSegs.0']
tcpHCOutSegs.0 = 884
mib-* = 215102
 UDP
SNMP['/usr/bin/snmpgetnext' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'UDP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'udpInDatagrams' 'udpOutDatagrams' 'udpInErrors' 'udpNoPorts']
udpInDatagrams.0 = 215104
udpOutDatagrams.0 = 220860
udpInErrors.0 = 0
udpNoPorts.0 = 11347
>> Runtime for poller module 'netstats': 0.5875 seconds with 4176 bytes
>> SNMP: [7/0.58s] MySQL: [0/0.00s]
#### Unload poller module netstats ####
OS
Device
#### Load poller module hr-mib ####
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OUQs' '-m' 'HOST-RESOURCES-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'hrSystemProcesses.0' 'hrSystemNumUsers.0']
hrSystemProcesses.0 = No Such Object available on this agent at this OID
hrSystemNumUsers.0 = No Such Object available on this agent at this OID
>> Runtime for poller module 'hr-mib': 0.0263 seconds with 1608 bytes
>> SNMP: [1/0.03s] MySQL: [0/0.00s]
#### Unload poller module hr-mib ####
OS
Device
#### Load poller module ucd-mib ####
SNMP['/usr/bin/snmpbulkwalk' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'UCD-SNMP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'systemStats']
systemStats = No Such Object available on this agent at this OID
Invalid snmp_walk() data = systemStats = No Such Object available on this agent at this OID
SNMP['/usr/bin/snmpget' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'UCD-SNMP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'laLoadInt.1' 'laLoadInt.2' 'laLoadInt.3']
laLoadInt.1 = No Such Object available on this agent at this OID
laLoadInt.2 = No Such Object available on this agent at this OID
laLoadInt.3 = No Such Object available on this agent at this OID
>> Runtime for poller module 'ucd-mib': 0.0816 seconds with 1936 bytes
>> SNMP: [2/0.08s] MySQL: [0/0.00s]
#### Unload poller module ucd-mib ####
OS
Device
#### Load poller module ipSystemStats ####
SNMP['/usr/bin/snmpbulkwalk' '-v3' '-l' 'noAuthNoPriv' '-n' "" '-u' 'USER' '-OQUs' '-m' 'IP-MIB' '-M' '/opt/librenms/mibs:/opt/librenms/mibs/apc' 'udp:HOSTNAME:161' 'ipSystemStats']
ipSystemStatsInReceives.ipv4 = 0
ipSystemStatsInReceives.ipv6 = 0
ipSystemStatsHCInReceives.ipv4 = 0
ipSystemStatsHCInReceives.ipv6 = 0
ipSystemStatsInOctets.ipv4 = 34770546
ipSystemStatsInOctets.ipv6 = 0
ipSystemStatsHCInOctets.ipv4 = 34770546
ipSystemStatsHCInOctets.ipv6 = 0
ipSystemStatsInHdrErrors.ipv4 = 0
ipSystemStatsInHdrErrors.ipv6 = 0
ipSystemStatsInNoRoutes.ipv4 = 0
ipSystemStatsInNoRoutes.ipv6 = 0
ipSystemStatsInAddrErrors.ipv4 = 0
ipSystemStatsInAddrErrors.ipv6 = 0
ipSystemStatsInUnknownProtos.ipv4 = 0
ipSystemStatsInUnknownProtos.ipv6 = 0
ipSystemStatsInTruncatedPkts.ipv4 = 0
ipSystemStatsInTruncatedPkts.ipv6 = 0
ipSystemStatsInForwDatagrams.ipv4 = 0
ipSystemStatsInForwDatagrams.ipv6 = 0
ipSystemStatsHCInForwDatagrams.ipv4 = 0
ipSystemStatsHCInForwDatagrams.ipv6 = 0
ipSystemStatsReasmReqds.ipv4 = 0
ipSystemStatsReasmReqds.ipv6 = 0
ipSystemStatsReasmOKs.ipv4 = 0
ipSystemStatsReasmOKs.ipv6 = 0
ipSystemStatsReasmFails.ipv4 = 0
ipSystemStatsReasmFails.ipv6 = 0
ipSystemStatsInDiscards.ipv4 = 0
ipSystemStatsInDiscards.ipv6 = 0
ipSystemStatsInDelivers.ipv4 = 236638
ipSystemStatsInDelivers.ipv6 = 0
ipSystemStatsHCInDelivers.ipv4 = 0
ipSystemStatsHCInDelivers.ipv6 = 0
ipSystemStatsOutRequests.ipv4 = 225621
ipSystemStatsOutRequests.ipv6 = 5657
ipSystemStatsHCOutRequests.ipv4 = 225621
ipSystemStatsHCOutRequests.ipv6 = 5657
ipSystemStatsOutNoRoutes.ipv4 = 0
ipSystemStatsOutNoRoutes.ipv6 = 0
ipSystemStatsOutForwDatagrams.ipv4 = 0
ipSystemStatsOutForwDatagrams.ipv6 = 0
ipSystemStatsHCOutForwDatagrams.ipv4 = 0
ipSystemStatsHCOutForwDatagrams.ipv6 = 0
ipSystemStatsOutDiscards.ipv4 = 0
ipSystemStatsOutDiscards.ipv6 = 0
ipSystemStatsOutFragReqds.ipv4 = 0
ipSystemStatsOutFragReqds.ipv6 = 0
ipSystemStatsOutFragOKs.ipv4 = 0
ipSystemStatsOutFragOKs.ipv6 = 0
ipSystemStatsOutFragFails.ipv4 = 0
ipSystemStatsOutFragFails.ipv6 = 0
ipSystemStatsOutFragCreates.ipv4 = 0
ipSystemStatsOutFragCreates.ipv6 = 0
ipSystemStatsOutTransmits.ipv4 = 0
ipSystemStatsOutTransmits.ipv6 = 0
ipSystemStatsHCOutTransmits.ipv4 = 0
ipSystemStatsHCOutTransmits.ipv6 = 0
ipSystemStatsOutOctets.ipv4 = 52220559
ipSystemStatsOutOctets.ipv6 = 0
ipSystemStatsHCOutOctets.ipv4 = 52220885
ipSystemStatsHCOutOctets.ipv6 = 0
ipSystemStatsInMcastPkts.ipv4 = 0
ipSystemStatsInMcastPkts.ipv6 = 0
ipSystemStatsHCInMcastPkts.ipv4 = 0
ipSystemStatsHCInMcastPkts.ipv6 = 0
ipSystemStatsInMcastOctets.ipv4 = 0
ipSystemStatsInMcastOctets.ipv6 = 0
ipSystemStatsHCInMcastOctets.ipv4 = 0
ipSystemStatsHCInMcastOctets.ipv6 = 0
ipSystemStatsOutMcastPkts.ipv4 = 0
ipSystemStatsOutMcastPkts.ipv6 = 5657
ipSystemStatsHCOutMcastPkts.ipv4 = 0
ipSystemStatsHCOutMcastPkts.ipv6 = 5657
ipSystemStatsOutMcastOctets.ipv4 = 0
ipSystemStatsOutMcastOctets.ipv6 = 0
ipSystemStatsHCOutMcastOctets.ipv4 = 0
ipSystemStatsHCOutMcastOctets.ipv6 = 0
ipSystemStatsInBcastPkts.ipv4 = 11347
ipSystemStatsInBcastPkts.ipv6 = 0
ipSystemStatsHCInBcastPkts.ipv4 = 11347
ipSystemStatsHCInBcastPkts.ipv6 = 0
ipSystemStatsOutBcastPkts.ipv4 = 120
ipSystemStatsOutBcastPkts.ipv6 = 0
ipSystemStatsHCOutBcastPkts.ipv4 = 120
ipSystemStatsHCOutBcastPkts.ipv6 = 0
ipSystemStatsDiscontinuityTime.ipv4 = 0:0:00:00.00
ipSystemStatsDiscontinuityTime.ipv6 = 0:0:00:00.00
ipSystemStatsRefreshRate.ipv4 = 0
ipSystemStatsRefreshRate.ipv6 = 0
ipv4
ipv6
