We have a couple of APC UPS systems in our network. We use SNMP and LibreNMS to check their status. The OID upsAdvBatteryReplaceIndicator (1.3.6.1.4.1.318.1.1.1.2.2.4.0) works perfect.
However there is also a recommended date for battery replacement. This is called upsAdvBatteryRecommendedReplaceDate (1.3.6.1.4.1.318.1.1.1.2.1.3). The outputs is a recommended date to replace the battery.
See output of a snmpwalk both OID’s:
$ snmpwalk -Os -c public -v 2c 192.168.1.100 1.3.6.1.4.1.318.1.1.1.2.2.4.0
iso.3.6.1.4.1.318.1.1.1.2.2.4.0 = INTEGER: 1
$ snmpwalk -Os -c public -v 2c 192.168.1.100 1.3.6.1.4.1.318.1.1.1.2.1.3
iso.3.6.1.4.1.318.1.1.1.2.1.3.0 = STRING: "10/18/2018"
Can the upsAdvBatteryReplaceIndicator be added to the check for APC UPS systems? We missed a couple of battery replacements. Would be great if LibreNMS can notify us when a battery needs replacing.
See also following topic that I created on the the Schneider Electric forum about this:
If testing or more info is needed please let me know!
