When I consult the API address for all bills and use the period=previous I got a response:
https://my.lnms.add/api/v0/bills?period=previous
“status”: “ok”,
“bills”: […],
“count”: 20
But when I try to get the period=previous for an specific bill, it returns nothing:
https://my.lnms.add/api/v0/bills/1?period=previous
“status”: “ok”,
“bills”: ,
“count”: 0
The bill id=1 does exist, consult it without the period works fine:
https://argus.tivit.corp/api/v0/bills/1
“status”: “ok”,
“bills”: […],
“count”: 1
P.S.: Bill list content ommited, not relevant, the count key shows that somithing exists.
Any ideas how to solve the issue?
Thanks.
Found that this seems to be a problem with the API module get_bill for quite some time. There is an issue open on github on Apr 2024 (#15980).
Just for reference I’m using lnms on a docker container and the validate output is:
/opt/librenms$ ./validate.php
LibreNMS | 25.2.0 (2025-02-23T10:02:21-03:00)
DB Schema | 2025_01_30_000121_add_ifindex_index_to_ports_table (315)
PHP | 8.3.17
Python | 3.12.9
Database | MariaDB 10.5.28-MariaDB-ubu2004
RRDTool | 1.9.0
SNMP | 5.9.4
[OK] Redis is functional
