Hi All,
Since a few days ago, I am facing the following issue in my Librenms setup. When I try to access to any device through the API, I have no problems and all it is correct:
http://hostname/device/900 where 900 is the id.
However, once I try to access to any interface to check its graphs or any other information:
I receive the 404 not found error because I have the following issue in url:
http://hostname/http:/hostnamedevice/device=900/tab=port/port=9191/
Anyone have coped with this issue before, it seems that the http://hostname is added twice during the redirection. Can be related with any of the updates of previuos dates?
This is my validate.php, it seems all is correct.
I can print more screenshots if you need it. I look forward to any anser, I will appreciate it.
Sebastia
