API not working, locally or remote via CURL
Hi Guys,
I seem unable to query/check the API when ever I run
curl -H ‘X-Auth-Token: xxxxxxx’ https://xxxx.xxxx.xxx/api/v0/oxidized
Can any one help with the error I am getting
curl: (60) SSL certificate problem: unable to get local issuer certificate
More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
is your Webserver pointing to LibreNMS running with a valid SSL Certificate and does listen on Port 443?
If so and you use a self signed certificate try curl with ‘-k’ option.
Ok - with the -k it works for a curl.
Any way I can get the oxidized process to do that too?
maybe this helps?
