Greetings,
I am trying to hook use the API alert transport to send alerts between my librenms and BMC TrueSight Infrastructure management system.
I have a url command which is working:
curl --location -X POST --header ‘Authorization: Basic YXBpdGVzdDphcGl0ZXN0MTIzNDU=’ -H ‘Content-Type: application/json’ --data ‘[{ “eventSourceHostName”: “Test1”, “eventSourceIPAddress”: “1.1.1.1”, “attributes”: { “CLASS”: “EVENT”, “mc_object_uri”: “”, “severity”: “CRITICAL”, “msg”: “LNMS-MESSAGE” } }]’ http://tsimprd1/bppmws/api/Event/create?routingId=integ_dc\&routingIdType=CELL_NAME
I tried build the aler transport on my librenms, but it seems Truesight is not getting the parameters as it should, so I am getting a bad status from the system:
{“responseTimeStamp”:“2022-11-10T10:19:57”,“statusCode”:“Event Object”,“statusMsg”:“BPPM-RWS40002E”}
Basically, the picture shows the config done in the alet transport, tried playing various configs, but still, same issue.
Will appreciate any help.
Jacob
- The output of
./validate.php
Last login: Thu Nov 10 10:08:39 IST 2022 on pts/1
-bash-4.2$ ./validate.php
| LibreNMS | 22.9.0-3-g06c361c |
| DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246) |
| PHP | 7.3.33 |
| Python | 3.6.8 |
| Database | MariaDB 10.5.13-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | 5.7.2 |
[OK] Composer Version: 2.4.4
[OK]
[FAIL] We have detected that your database schema may be wrong
Database: missing index (plugins/plugins_version_plugin_name_unique)
Database: incorrect column (ports_adsl/adslLineCoding)
Database: incorrect column (ports_adsl/adslLineType)
Database: incorrect column (ports_adsl/adslAtucInvVendorID)
Database: incorrect column (ports_adsl/adslAtucInvVersionNumber)
Database: incorrect column (ports_adsl/adslAtucCurrSnrMgn)
Database: incorrect column (ports_adsl/adslAtucCurrAtn)
Database: incorrect column (ports_adsl/adslAtucCurrOutputPwr)
Database: incorrect column (ports_adsl/adslAtucCurrAttainableRate)
Database: incorrect column (ports_adsl/adslAtucChanCurrTxRate)
Database: incorrect column (ports_adsl/adslAturInvSerialNumber)
Database: incorrect column (ports_adsl/adslAturInvVendorID)
Database: incorrect column (ports_adsl/adslAturInvVersionNumber)
Database: incorrect column (ports_adsl/adslAturChanCurrTxRate)
Database: incorrect column (ports_adsl/adslAturCurrSnrMgn)
Database: incorrect column (ports_adsl/adslAturCurrAtn)
Database: incorrect column (ports_adsl/adslAturCurrOutputPwr)
Database: incorrect column (ports_adsl/adslAturCurrAttainableRate)
Database: missing column (ports_stp/vlan)
Database: missing column (ports_stp/port_index)
Database: incorrect column (ports_stp/designatedCost)
Database: missing index (ports_stp/ports_stp_device_id_vlan_port_index_unique)
Database: extra index (ports_stp/ports_stp_device_id_port_id_unique)
Database: missing table (ports_vdsl)
Database: missing column (stp/vlan)
Database: incorrect column (users/auth_id)
Database: missing column (users_widgets/widget)
Database: extra column (users_widgets/widget_id)
Database: incorrect index (users_widgets/user_id)
Database: extra table (widgets)
Run the following SQL statements to fix it
SQL Statements:
ALTER TABLE plugins ADD UNIQUE plugins_version_plugin_name_unique (version,plugin_name);
ALTER TABLE ports_adsl CHANGE adslLineCoding adslLineCoding varchar(8) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslLineType adslLineType varchar(16) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAtucInvVendorID adslAtucInvVendorID varchar(16) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAtucInvVersionNumber adslAtucInvVersionNumber varchar(16) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAtucCurrSnrMgn adslAtucCurrSnrMgn decimal(5,1) NOT NULL DEFAULT ‘0.0’ ;
ALTER TABLE ports_adsl CHANGE adslAtucCurrAtn adslAtucCurrAtn decimal(5,1) NOT NULL DEFAULT ‘0.0’ ;
ALTER TABLE ports_adsl CHANGE adslAtucCurrOutputPwr adslAtucCurrOutputPwr decimal(5,1) NOT NULL DEFAULT ‘0.0’ ;
ALTER TABLE ports_adsl CHANGE adslAtucCurrAttainableRate adslAtucCurrAttainableRate int NOT NULL DEFAULT ‘0’ ;
ALTER TABLE ports_adsl CHANGE adslAtucChanCurrTxRate adslAtucChanCurrTxRate int NOT NULL DEFAULT ‘0’ ;
ALTER TABLE ports_adsl CHANGE adslAturInvSerialNumber adslAturInvSerialNumber varchar(32) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAturInvVendorID adslAturInvVendorID varchar(16) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAturInvVersionNumber adslAturInvVersionNumber varchar(16) NOT NULL DEFAULT ‘’ ;
ALTER TABLE ports_adsl CHANGE adslAturChanCurrTxRate adslAturChanCurrTxRate int NOT NULL DEFAULT ‘0’ ;
ALTER TABLE ports_adsl CHANGE adslAturCurrSnrMgn adslAturCurrSnrMgn decimal(5,1) NOT NULL DEFAULT ‘0.0’ ;
and 15 more…
Attempt to fix this issue (y or n)?:y
Failed to apply fix.
[OK] MySQl and PHP time match
[OK] Redis is functional
[WARN] Your install is over 24 hours out of date, last update: Thu, 29 Sep 2022 04:32:10 +0000
You can switch back to master with git checkout master
