- The output of
./validate.php
Hi All, hope the day is well and you and yours are safe!
Have an interesting “flap” issue:
Polling and discovery of SNMP “extended” v3 Applications are working wonderfully, but Application discovery (enable → disable → enable ) flap is causing gaps or removal of data from graphs.
Adjusted to 7 minutes on the crontab since latency is a bit extreme on a few nodes (need to set up distributed pollers, but goal is to solve flap issue before expanding the problem).
Output that may be of merit:
BEGIN output of ./validate.php
$ ./validate.php
LibreNMS | 1.62-123-g83dd1f0a1
DB Schema | 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164)
PHP | 7.2.24-0ubuntu0.18.04.4
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.10.5
END output of ./validate.php
BEGIN cat /etc/cron.d/librenms
$ cat /etc/cron.d/librenms
# Using this cron file requires an additional user on your system, please see install docs.
*/7 * * * * librenms /opt/librenms/discovery.php -h new >> /dev/null 2>&1
*/7 * * * * librenms /opt/librenms/cronic /opt/librenms/poller-wrapper.py 8
* * * * * librenms /opt/librenms/alerts.php >> /dev/null 2>&1
*/7 * * * * librenms /opt/librenms/poll-billing.php >> /dev/null 2>&1
*/3 * * * * librenms /opt/librenms/check-services.php >> /dev/null 2>&1
# nagios service checks
*/3 * * * * librenms /opt/librenms/services-wrapper.py 1
# Weather map plugin
*/6 * * * * librenms /opt/librenms/html/plugins/Weathermap/map-poller.php >> /dev/null 2>&1
# Daily maintenance script. DO NOT DISABLE!
# If you want to modify updates:
# Switch to monthly stable release: https://docs.librenms.org/General/Releases/
# Disable updates: https://docs.librenms.org/General/Updating/
15 0 * * * librenms /opt/librenms/daily.sh >> /dev/null 2>&1
END cat /etc/cron.d/librenms
edit: for syntax formatting.
