Hi there,
When creating a new filter in config.php, for example:
$config[‘os’][‘iosxe’][‘disabled_sensors_regex’][‘temperature’] = “/Gi[0-9]//”;
It just works for new added nodes isn’t it? Or will the ‘not wanted’ objects be removed (rrd files and mysql entries)? It do not seems that this is the case. Or do I miss something?
Thanks in advance.
Gert-Jan
| LibreNMS | 24.2.0-30-g8c4205c61 (2024-03-19T10:24:07+01:00) |
| DB Schema | 2024_02_07_151845_custom_map_additions (290) |
| PHP | 8.2.8 |
| Python | 3.9.2 |
| Database | MariaDB 10.5.19-MariaDB-0+deb11u2 |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[OK] Composer Version: 2.7.1
[OK] Redis is functional
