Does anybody use VRF functionality on Arista devices? We have BGP peers running over our edge devices and do not get alerts for BGP Peers dropping when we have circuit issues. When viewing the affected devices on the Web GUI I can see the ‘Routing’ tab is not showing on the device page.
The devices are Arista 7160 series, these are also used at the Spine level and BGP peer monitoring works without issue. The only difference we see is that peers in the edge devices are within a VRF
Troubleshooting so far has consisted of deleting/relearning the device and confirming that the vrf and cisco-vrf modules are loaded.
My validate.php is as follows:
bash-4.2$ ./validate.php
Component Version LibreNMS 1.39 DB Schema 249 PHP 7.0.25 MySQL 5.5.56-MariaDB RRDTool 1.7.0 SNMP NET-SNMP 5.7.2 ====================================
[OK] Composer Version: 1.6.5
[FIX] Check the cron job to make sure it is running and using discovery-wrapper.py
Has anybody else noticed this issue/found a way to monitor this?
Thanks,
Rob
