Hi, when creating the template for Arista BGP check I noticed $value[‘astext’] comes in empty.
From what I understand this is where the neighbor description should be.
Below pasting BGP, SNMP outputs and ./poller.php
Many thanks for looking into this, Mat
spn-lab-001(config)#sh ip bgp summ
BGP summary information for VRF default
Router identifier 10.1.0.1, local AS number 65000
Neighbor Status Codes: m - Under maintenance
Description Neighbor V AS MsgRcvd MsgSent InQ OutQ Up/Down State PfxRcd PfxAcc
clf-lab-101-a 10.1.1.3 4 65001 184 265 0 0 00:08:53 Idle(Admin)
clf-lab-101-b 10.1.1.5 4 65001 206 205 0 0 03:10:33 Estab 13 13
blf-lab-001-a 10.1.1.7 4 65001 203 204 0 0 03:10:32 Estab 14 14
blf-lab-001-b 10.1.1.9 4 65001 205 204 0 0 03:10:32 Estab 13 13
.1.3.6.1.4.1.30065.4.1.1.2.1.14.1.1.4.10.1.1.3 = STRING: “clf-lab-101-a”
.1.3.6.1.4.1.30065.4.1.1.2.1.14.1.1.4.10.1.1.5 = STRING: “clf-lab-101-b”
.1.3.6.1.4.1.30065.4.1.1.2.1.14.1.1.4.10.1.1.7 = STRING: “blf-lab-001-a”
.1.3.6.1.4.1.30065.4.1.1.2.1.14.1.1.4.10.1.1.9 = STRING: “blf-lab-001-b”
./poller.php
1 updated
Modules status: Global+
OS
Device
SQL[SELECT * FROM bgpPeers
AS B LEFT JOIN vrfs
AS V ON B
.vrf_id
= V
.vrf_id
WHERE B
.device_id
= ? [5] 0.51ms]
aristaBgp4V2PeerRemoteAs.1.ipv4."" = 65001
aristaBgp4V2PeerState.1.ipv4."" = idle
aristaBgp4V2PeerAdminStatus.1.ipv4."" = halted
aristaBgp4V2PeerInUpdates.1.ipv4."" = 32
aristaBgp4V2PeerOutUpdates.1.ipv4."" = 28
aristaBgp4V2PeerInTotalMessages.1.ipv4."" = 183
aristaBgp4V2PeerOutTotalMessages.1.ipv4."" = 263
aristaBgp4V2PeerFsmEstablishedTime.1.ipv4."" = 410
aristaBgp4V2PeerInUpdatesElapsedTime.1.ipv4."" = 0
aristaBgp4V2PeerLocalAddr.1.ipv4."*" = “”
array (
‘bgpPeerState’ => ‘idle’,
‘bgpPeerAdminStatus’ => ‘halted’,
‘bgpPeerInUpdates’ => ‘32’,
‘bgpPeerOutUpdates’ => ‘28’,
‘bgpPeerInTotalMessages’ => ‘183’,
‘bgpPeerOutTotalMessages’ => ‘263’,
‘bgpPeerFsmEstablishedTime’ => ‘410’,
‘bgpPeerInUpdateElapsedTime’ => ‘0’,
‘bgpLocalAddr’ => ‘’,
SQL[UPDATE bgpPeers
set bgpPeerInTotalMessages
=?,bgpPeerOutTotalMessages
=?,bgpPeerFsmEstablishedTime
=? WHERE device_id
= ? AND bgpPeerIdentifier
= ? [“183”,“263”,“410”,5,“10.1.1.3”] 1.44ms]
SQL[SELECT * FROM bgpPeers_cbgp WHERE device_id
= ? AND bgpPeerIdentifier = ? [5,“10.1.1.3”] 0.53ms]
ipv4 unicast
aristaBgp4V2PrefixInPrefixesAccepted.1.ipv4."".ipv4.unicast = 18
aristaBgp4V2PrefixInPrefixesAccepted.1.ipv4."".ipv4.unicast = 13
aristaBgp4V2PrefixInPrefixesAccepted.1.ipv4."".ipv4.unicast = 14
aristaBgp4V2PeerState.1.ipv4."" = established
aristaBgp4V2PeerAdminStatus.1.ipv4."" = running
aristaBgp4V2PeerInUpdates.1.ipv4."" = 12
aristaBgp4V2PeerOutUpdates.1.ipv4."" = 12
aristaBgp4V2PeerInTotalMessages.1.ipv4."" = 204
aristaBgp4V2PeerOutTotalMessages.1.ipv4."" = 203
aristaBgp4V2PeerFsmEstablishedTime.1.ipv4."" = 11310
aristaBgp4V2PeerInUpdatesElapsedTime.1.ipv4."" = 11286
aristaBgp4V2PeerLocalAddr.1.ipv4."*" = "0A 01 01 04 "
array (
‘bgpPeerState’ => ‘established’,
‘bgpPeerAdminStatus’ => ‘running’,
‘bgpPeerInUpdates’ => ‘12’,
‘bgpPeerOutUpdates’ => ‘12’,
‘bgpPeerInTotalMessages’ => ‘204’,
‘bgpPeerOutTotalMessages’ => ‘203’,
‘bgpPeerFsmEstablishedTime’ => ‘11310’,
‘bgpPeerInUpdateElapsedTime’ => ‘11286’,
‘bgpLocalAddr’ => ‘10.1.1.4’,
SQL[UPDATE bgpPeers
=?,bgpPeerInUpdateElapsedTime
=? WHERE device_id
= ? [“204”,“203”,“11310”,“11286”,5,“10.1.1.5”] 1.61ms]
= ? AND bgpPeerIdentifier = ? [5,“10.1.1.5”] 0.34ms]
ipv4 unicast
aristaBgp4V2PeerInUpdates.1.ipv4."" = 10
aristaBgp4V2PeerOutUpdates.1.ipv4."" = 11
aristaBgp4V2PeerInTotalMessages.1.ipv4."" = 201
aristaBgp4V2PeerOutTotalMessages.1.ipv4."" = 202
aristaBgp4V2PeerFsmEstablishedTime.1.ipv4."" = 11309
aristaBgp4V2PeerInUpdatesElapsedTime.1.ipv4."" = 11284
aristaBgp4V2PeerLocalAddr.1.ipv4."*" = "0A 01 01 06 "
array (
‘bgpPeerInUpdates’ => ‘10’,
‘bgpPeerOutUpdates’ => ‘11’,
‘bgpPeerInTotalMessages’ => ‘201’,
‘bgpPeerOutTotalMessages’ => ‘202’,
‘bgpPeerFsmEstablishedTime’ => ‘11309’,
‘bgpPeerInUpdateElapsedTime’ => ‘11284’,
‘bgpLocalAddr’ => ‘10.1.1.6’,
SQL[UPDATE bgpPeers
=? WHERE device_id
= ? [“201”,“202”,“11309”,“11284”,5,“10.1.1.7”] 1.55ms]
= ? AND bgpPeerIdentifier = ? [5,“10.1.1.7”] 0.42ms]
ipv4 unicast
aristaBgp4V2PeerInTotalMessages.1.ipv4."" = 203
aristaBgp4V2PeerLocalAddr.1.ipv4."*" = "0A 01 01 08 "
array (
‘bgpPeerInTotalMessages’ => ‘203’,
‘bgpLocalAddr’ => ‘10.1.1.8’,
SQL[UPDATE bgpPeers
=? WHERE device_id
= ? [“203”,“202”,“11309”,“11284”,5,“10.1.1.9”] 1.48ms]
= ? AND bgpPeerIdentifier = ? [5,“10.1.1.9”] 0.33ms]
