- The output of
./validate.php
./validate.php:
| LibreNMS | 24.2.0 (2024-03-01T10:55:24+00:00) |
| DB Schema | 2024_02_07_151845_custom_map_additions (290) |
| PHP | 8.2.16 |
| Python | 3.11.8 |
| Database | MariaDB 10.5.24-MariaDB-1:10.5.24+maria~ubu2004 |
| RRDTool | 1.8.0 |
| SNMP | 5.9.4 |
[OK] Redis is functional
RX/TX values for dBm don’t seem to be mapping correctly.
snmpwalk returns them as:
iso.3.6.1.2.1.99.1.1.1.4.100302213 = INTEGER: 4082
LibreNMS seems to agree:
“poller_type”: “snmp”,
“sensor_oid”: “.1.3.6.1.2.1.99.1.1.1.4.100302213”,
“sensor_index”: “100302213”,
“sensor_type”: “entity-sensor”,
“sensor_descr”: “DOM RX Power For Ethernet2”,
“group”: “SFPs”,
“sensor_divisor”: 1,
“sensor_multiplier”: 1,
“sensor_current”: 4082,
“sensor_limit”: 2.5,
“sensor_limit_warn”: 0.5,
“sensor_limit_low”: -16.4,
“sensor_limit_low_warn”: -14.4,
“sensor_alert”: 1"sensor_custom": “No”,
“entPhysicalIndex”: “100302213”,
However the conversion from reported values to expected dBm doesn’t seem to work. I am unsure if this is a scale error, or something else.
That “sensor_current” is populated pretty much as-is in the dBm:
DOM RX Power for Ethernet2;
Value: 4087 (dbm)
This causes alerts on all ports with transceiver details.
Limit values are pulled in correctly, but the actual power used is not.
High Alarm High Warn Low Alarm Low Warn
Rx Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Et2 -3.89 2.50 0.50 -16.40 -14.40
Interestingly there is:
iso.3.6.1.2.1.99.1.1.1.6.100302213 = STRING: “mW”
Which maybe denotes the correct units for:
Hardware polled is: DCS-7280SR
