Aruba InstantOn 1930 Switches
This if for Aruba’s new line of InstantOn 1930 switches. Currently, LibreNMS only picks up the interfaces and general info but none of the CPU, Memory, Temperature, POE graphs.
Discovery: https://p.libren.ms/view/b886cf78
Poller: https://p.libren.ms/view/f570f147
SNMP Walk: https://p.libren.ms/view/c73414b2
Mibs: https://community.arubainstanton.com/ehvxd43934/attachments/ehvxd43934/InstantOnSoftware/1/3/1930_MIBS_1.0.1.116.zip
Any updates on this state?
i would also like an update on this for the 1960’s as well.
No CPU, No Temps, No fans, No detailed port info
MIB download link doesn’t work. 404.
Found the MIBs online.
Did some checking… but there’s little to add. The only thing I could potentially add is the PoE total budget and consumed budget. That’s really all there is.
This isn’t uncommon for cloud managed switches. eg. Cisco Meraki is also quite sparse on giving out details over SNMP.
is it the same for the 1960. i guess they really lock them down.
https://community.arubainstanton.com/blogs/jamie-easly1/2021/11/01/instanton1960switchsoftwareportal
