LibreNMS running on VM @ubuntu 18.04
Validate.php:
The error is related to weathermap and seems unlikely to be the cause.
$ ./validate.php
Component | Version |
LibreNMS | 21.3.0-90-g0e79413a5 |
DB Schema | 2020_12_14_091314_create_port_groups_table (206) |
PHP | 7.4.16 |
Python | 3.6.9 |
MySQL | 10.5.9-MariaDB-1:10.5.9+maria~bionic |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 2.0.12
Files:
/opt/librenms/html/plugins/Weathermap/configs/Core_Dist.conf
Whenever cisco-cef is polled on ASR920 devices there are 8 log entries on the device “snmp: count not valid”.
The command I’ve used to test:
./poller.php -h XXX -r -f -p -d -m cisco-cef
Hardware:
ASR-920-24SZ-M
Tried on these OS versions:
Cisco IOS-XE PPC_LINUX_IOSD-UNIVERSALK9_NPE-M 16.9.3 (Fuji)
Cisco IOS-XE PPC_LINUX_IOSD-UNIVERSALK9_NPE-M 16.9.1a (Fuji)
Cisco IOS-XE 15.6(2)SP3 (UNIVERSALK9_NPE)
Cisco IOS-XE 15.5(3)S5 (UNIVERSALK9_NPE)
Cisco IOS-XE 15.5(2)S2 (UNIVERSALK9_NPE)
I’m guessing something needs to be adjusted for ios xe regarding this poller module.
If you need me to post the output I get when I run the poller module give me a headsup and I’ll post it.
