Assistance enabling MPLS
Hi team,
I found this MPLS feature on Librenms that was enabled in ver1.53 and we are using v1.67. I have MPLS enabled on both Poller and Discovery tab under Global Settings but it appears that I am missing some steps cause I am not able to see MPLS under routing and was wondering if one of the experts here can help me out. We use Cisco Nexus, ASR1001 and ME switches.
LibreNMS 1.67-82-g2a515d308
DB Schema 2020_09_22_172321_add_alert_log_index (174)
PHP 7.2.24-0ubuntu0.18.04.6
Python 3.6.9
MySQL 10.1.44-MariaDB-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.10.13
[WARN] PHP version 7.3 is the minimum supported version as of November, 2020. We recommend you update PHP to a supported version (7.4 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Kind regards,
Vik
MPLS currently available only for Nokia devices
Thank you for the info, Zombah.
It would be interesting to see if anyone using snmptraps to get MPLS or LSP info or anything else in LibreNMS to monitor LDP neighbours.
