Hi Team,
I was wondering if anyone has worked on SNMPTrap handlers for Cisco devices. I have enabled Traps from Cisco switches and ASR and but due to the default list of handlers, i am missing some of the information.
- The output of
./validate.php
| LibreNMS | 1.67-82-g2a515d308 |
| DB Schema | 2020_09_22_172321_add_alert_log_index (174) |
| PHP | 7.2.24-0ubuntu0.18.04.6 |
| Python | 3.6.9 |
| MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
| RRDTool | 1.7.0 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.13
[WARN] PHP version 7.3 is the minimum supported version as of November, 2020. We recommend you update PHP to a supported version (7.4 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
Kind regards,
Vik
