I would like some assistance in monitoring asterisk PJSIP extentions.
I have followed the instructions to monitor asterisk applications and that is working correctly however we are using PJSIP instead of ChanSIP and as a result, the sip show peers command does not return results. The closest command would be pjsip show endpoints, but this does not have a summary at the end that indicates online and offline peers.
So i need help changing this line:
$ASCLI -rx ‘sip show peers’ | awk ‘/sip peers/ { print “SipPeers=” $1 “\nSipMonOnline=” $5 “\nSipMonOffline=” $7 “\nSipUnMonOnline=” $10 “\nSipUnMonOffline=” $12}’
to accommodate PJSIP instead.
Any help would be greatly appreciated.
Additional information might be helpful:
- Asterisk version 15 and 16 (multiple instances)
- Active channels / calls seems to be reporting correctly
