Hi Guys
i need you help with the auto-discovery function
our new distributed librenms deployment looks like this
1 web node - pol and discovery disabled - default poller group
1 poller node - only node for pol and discovery - poller group 2
1 database server
1 redis,rrd,memcache server.
we are experiencing issues with the auto-discovery part
discover by ip enabled - global and on the poller node.
XDP enabled - global and on the poller node.
when we ran the discovery.php the first time the server found 79 devices and added them to the database.
we found that we where missing quite a few devices and should have been added as well, but for some reason was not added.
when i ran the discovery job again with some debug info i can see that the job is trying to discover the devices but it looks like it is not identifying the IP address and therefore fails the discovery process.
the devices do not have a DNS record, hence the discover by IP.
i cant for the life of me figure out why the IP address is not discovered. we have devices of similar model, and config that is beeing discovered fine.
the main part i am noticing is from the discovery log is
discovering DC1OOB-SWN0804.intra.coop
name lookup of DC1OOB-SWN0804.intra.coop failed
SQL[[1;33minsert into
eventlog(reference,type,datetime,severity,message,username,device_id) values (?, ?, ?, ?, ?, ?, ?) [0;33m[null,“discovery”,“2023-03-22 11:58:50”,5,“CDP discovery of DC1OOB-SWN0804.intra.coop failed - Check name lookup”,“”,6][0m 2ms] -
discovering
Discovery failed: ‘’ is not a valid ip or dns name
validate php output
[librenms@nmsprdpol01 ~]$ ./validate.php
| LibreNMS | 23.2.0-30-g0e322ae5d (2023-03-13T16:19:23+01:00) |
| DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
| PHP | 8.1.16 |
| Python | 3.6.8 |
| Database | MariaDB 10.3.35-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.5.4
[OK] MySQl and PHP time match
[OK] Redis is functional
