thanks for the fast reply i hope this is what you need:
]# ./validate.php
| Component |
Version |
| LibreNMS |
1.31-3-gd5bfd1d |
| DB Schema |
205 |
| PHP |
5.4.16 |
| MySQL |
5.5.52-MariaDB |
| RRDTool |
1.4.8 |
| SNMP |
NET-SNMP 5.7.2 |
[WARN] Some devices have not been polled in the last 5 minutes.
You may have performance issues. Check your poll log and see: http://docs.librenms.org/Support/Performance/
172.20.100.52
172.16.10.94
172.16.10.88
172.27.24.52
172.16.10.96
172.16.10.86
172.27.24.244
172.20.100.202
172.27.24.35
172.27.24.246
and 1 more…
?php
Have a look in includes/defaults.inc.php for examples of settings you can set here. DO NOT EDIT defaults.inc.php!
Database config
$config[‘db_host’] = ‘localhost’;
$config[‘db_user’] = ‘librenms’;
$config[‘db_pass’] = ‘********’;
$config[‘db_name’] = ‘librenms’;
// This is the user LibreNMS will run as
//Please ensure this user is created and has the correct permissions to your install
$config[‘user’] = ‘librenms’;
This should only be set if you want to force a particular hostname/port
It will prevent the web interface being usable form any other hostname
$config[‘base_url’] = “/”;
Enable this to use rrdcached. Be sure rrd_dir is within the rrdcached dir
and that your web server has permission to talk to rrdcached.
#$config[‘rrdcached’] = “unix:/var/run/rrdcached.sock”;
Default community
$config[‘snmp’][‘community’][] = “public”;
$config[‘snmp’][‘community’][] = “********”;
Authentication Model
$config[‘auth_mechanism’] = “mysql”; # default, other options: ldap, http-auth
#$config[‘http_auth_guest’] = “guest”; # remember to configure this user if you use http-auth
List of RFC1918 networks to allow scanning-based discovery
#$config[‘nets’][] = “10.0.0.0/8”;
Uncomment the next line to disable daily updates
#$config[‘update’] = 0;
Number in days of how long to keep old rrd files. 0 disables this feature
$config[‘rrd_purge’] = 0;
Uncomment to submit callback stats via proxy
#$config[‘callback_proxy’] = “hostname:port”;
Set default port association mode for new devices (default: ifIndex)
#$config[‘default_port_association_mode’] = ‘ifIndex’;
Enable the in-built billing extension
$config[‘enable_billing’] = 1;
Enable the in-built services support (Nagios plugins)
$config[‘show_services’] = 1;
$config[‘nagios_plugins’] = “/usr/lib/nagios/plugins”;
Enable auto discovery methods
$config[‘discovery_modules’][‘discovery-arp’] = 1;
$config[‘addhost_alwayscheckip’] = true;
$config[‘fping’] = “/usr/sbin/fping”;
$config[‘allow_unauth_graphs’] = 1;
