Hello, i have configured autodiscover fllowing the oficial docs, configured snmp comunity, nets array and enabled discover by ip, but nonnne device is added to the inventory, even if i run autorodiscover in console, there is not error message but the devices are not added. is there a way to run a debug command to see where is the mistake i made?
Can you add any of those devices manually in the GUI? Device -> Add device.
Check /opt/librenms/logs/librenms.log for any hints
Yes i can add them manually, all graphics works fine, it is the autodiscover that does not automatically add them to the inventory
Run through troubleshooting from this thread Autodiscovery by IP
