AVAGO QSFP±40G-SR4 optics (part number: 740-032986) for Juniper import with no “Tx Power” values. I believe these are Juniper branded optics.
This is not unexpected for this optic, the “diagnostics optics” Juniper command shows that this optic does not have Tx/Output power thresholds defined (“Not supported”).
The sensor “lane 1 Tx Power” in particular keeps being automatically deleted and re-added periodically (e.g. once a week) therefore overriding manually set thresholds within LibreNMS and therefore triggering false alerts from the “Sensor over limit” alert. I cannot simply turn alerts off for this lane as when the sensor gets deleted and re-added, that setting is reset.
Suggested values from Juniper can be seen here, "Transmitter output power, each lane (maximum/maximum)
Is anyone aware of a solution or workaround for this issue?
./validate.php: paste.sh · encrypted pastebin
