For example, CTC group device’s services are showing other services from other device groups.
But for showing devices from CTC group, it showed the correct devices from CTC group.
Just had trouble with showing services from a certain group.
An all services availability map from all devices is working fine.
Any help will be appreciated.
Thank you.
Component | Version |
LibreNMS | 1.70.1-32-gb07b81021 |
DB Schema | 2020_11_02_164331_add_powerstate_enum_to_vminfo (191) |
PHP | 7.4.3 |
Python | 3.8.5 |
MySQL | 10.3.25-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.0.8
Cannot load Zend OPcache - it was already loaded
[WARN] Your install is over 24 hours out of date, last update: Wed, 13 Jan 2021 13:23:47 +0000
I had ran daily.sh but it is not fixing the widget.
