Availability map widget not sorting by Device Group properly
Someone else posted a while ago some problems with the availability map widget when using device groups. See here: Availability Map not sorting by Device Group properly
I am having the exact same issues.
Is this easy to fix? In the original thread it is mentioned exactly where in the code the issue lies, but i’m afraid i’m no coder…
Thanks!
Output of validate.php:
LibreNMS  | 23.2.0 (2023-02-23T23:27:42+01:00)
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248)
PHP       | 8.2.4
Python    | 3.9.14
Database  | MariaDB 10.5.16-MariaDB
SNMP      | 5.9.1
[OK]    Composer Version: 2.5.4
[OK]    MySQl and PHP time match
[OK]    No python wrapper pollers found
[OK]    Redis is functional
PS. The issue is most easily spotted when configuring the Availability Map widget to show only services and then select only a single device group (obviously make sure that you have a group with devices in it).
In this case I would expect to see only services from devices in the selected group, which does not work as expected.
