Availability map with custom icons
Hi guys,
I’m looking for a solution to have a something like availability map but instead of up | up | up, i would like to have some specific value (Input voltage), for example 120V | 120V | 120 …
Or another widget that can help me to see all my UPSs and input voltage!
Another words, I would like to know if its possible to modify widget that way, to chose different data on it, or probably to use another widget to see required data for many devices.
Thanks ! Have a great day!
Workaround, would be great to see instead of $device->stateName, but the value( sensor_current) for this specific sensor (sensor_index = 101, sensor_descr = Input).
Could you help me with this a bit?
Or, if it helps you to understand my idea, we can simply collect this data from devices in Power group and show in one page or widget. Would be great!
Screenshot
