can be grouped and displayed like wigglymaps or alertlists, so you can build clean dashboards for your groups.
Currently only the global availibilitymap can be filtered. The filtering affects the Availibility-map widget so technically there only exists one availibilitymap vor all dashboards.
Thats bad and unhandy for separate technical contexts.
Kind Regards,
Mirko
