Hi Community,
request a AVM FritzBox integration in LibreNMS like User TAFKAS has done this for Munin - networked resource monitoring tool
Here is the fritzbox-munin plugin as example:
Kindly regards
Hi Community,
Kindly regards
I’m on it since a while, depending what time allows.
But it’s not such easy as it should, because AVM FritzBox doesn’t support SNMP.
An elegant way has to be found to do TR64 API calls.
Also FritzBoxes having some inconsistence between API Versions and Modells, which doesn’t make it easier to handle.
So i’m still on finding concept and thinking about the best way to integrate it into system.
i’m also interested on this, any news?
not yet.
Due lack of SNMP Support on AVM products, poller has to be enhanced to also talk TR64 with AVM Products, after this whole device has to be implemented, which is on a FritzBox quiet a lot of stuff.
At moment i do not have the time to start implementing this.
If you like to, feel free to start to code parts of it.
