Backup tool with or without librenms
Hi guys.
Im thinking about some tool to backup all monitored hosts configuration.
I created a crontab perl routing that sshs into a host list, and print their current config.
I would like to know if is there some similar option in the librenms ecosystem.
It would be great to integrate this so i dont need to keep track of multiple host lists.
If not …is it possible to use librenms host list to create custom process ?
It would be also great if you could save the “diff” output when some config has changed.
Any feedback about this will be helpfull.
Regards.
Leandro.
Oxidized
https://docs.librenms.org/Extensions/Oxidized/
