Bandwidth Monitoring per IP
Hello All,
I hope you are doing good.
I have a question, is it possible to know the amount of bandwidth transferred from an ethernet port to an IP ?
If not, is there a way to accomplish that ?
Best Regards,
Safiullah
You need to use netflow to accomplish this (or similar). It’s not something LibreNMS can do.
Many thanks for the quick reply.
I am using netflow on the routers and its creating flows, can it is possible for libre to draw the graphs ?
means any possibility of netflow in LibreNMS ?
I haven’t been able to configure NFsen properly … Please correct me if i am wrong. LibreNMS will only show graphs if NFsen is showing graphs, and my understanding is, that when NFsen can draw a graph, Libre will be able to get that graphs from NFsen and display in Libre.
Am i right ?
That is correct yes, we have some limited docs on the setup of this. I’d suggest taking a look at github issues, here and the old google groups to see if you can glean any info on how to get it working.
Again many thanks for the Quick reply.
please do me a favor, can you please tell me where will it show those graphs in LibreNMS ? i havent seen any screenshots of that.
It will be a new tab in the device page
