I want to try to run LibreNMS in Docker. I have a Debian Buster with Docker installed.
I don’t undertstand how to configure the MariaDB side.
Need I an other docker for mariadb?
Someone could help with basic docker steps?
Kind regards.
Kind regards.
Perhaps you get some pointers here: https://jasonloongphotos.com/2017/synology-snmp-network-monitoring-with-librenms-docker/
Also, make sure to add the APP key including the “base64:” in the beginning; that was preventing me from using it.
Thanks!
I read the guide and it works well with jarischaefer’s container.
The problem is that if I reboot the host, the containers doesn’t start automatically on boot, how could I configure this?
Thanks for your help.
Kind regards.
The funny thing is, I just tried that guide and it didn’t work ![]()
I can’t help you with the automatic restart on boot, sorry. I have it running in a Synology so I have a switch for it there in the GUI, that works.
I know to start in a host boot, just update the rstart policy:
docker update --restart=always mariadb
docker update --restart=always librenms
Kind regards.
