Best upgrade path from 22.10.0 to the current release (24.6.0)
Hey.
Well, I messed up, I disabled the daily update and I ended up way way behind the upgrades.
So yeah, what’s the best/less worst path to upgrade from 22.10.0 to 24.6.0, knowing I already have a working PHP 8.1 installation on this machine ?
As it runs on a VM, I plan to do a snapshot and DB dump before the upgrade (both with disabled crontabs).
Thanks.
Sounds like you have a good plan. It should be fine.
I did some upgrades on some 5 year old versions that had no version number etc and it worked fine.
I believe services are used instead of crontab now.
