Hi
I hope someone can help me with an issue I am having on LibreNMS where if I put my Cisco devices on SNMPv3, Libre loses the ability to see all the BGP and OSPF routes.
I am using a pair of Cisco ASR 1002x routers running version 17.6.3a.
On SNMPv3 or 2c there is no issue with any other module/ information being received from the device on Libre, it is only routing.
I have run a ./poller.php on one of these devices while on SNMPv3 and this is the output for the bgp-peer module:
RRD[update /data/rrd/“HOSTNAME”/poller-perf-bgp-peers.rrd N:0.0032839775085449]
RRDtool Output: OK u:0.01 s:0.01 r:21.22
Modules status: Global-
OS
Device
Module [ junose-atm-vp ] disabled globally.
OS
Device
Module [ printer-supplies ] disabled globally.
Modules status: Global+
OS
Device
Load poller module ucd-diskio
SQL[SELECT * FROM ucd_diskio
WHERE device_id
= ? [350] 0.49ms]
Runtime for poller module ‘ucd-diskio’: 0.0010 seconds with 48 bytes
SNMP: [0/0.00s] MySQL: [1/0.00s] RRD: [1/0.00s]
Unload poller module ucd-diskio
Has anyone encountered this issue before, if so, how did you solve it?
Component | Version |
LibreNMS | 23.1.1 (2023-02-09T19:33:37+00:00) |
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
PHP | 8.1.15 |
Python | 3.10.10 |
Database | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~focal |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
[OK]
[OK] MySQl and PHP time match
[OK] Redis is functional
