Component | Version |
LibreNMS | 22.11.0 (2022-11-26T16:55:27+00:00) |
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (248) |
PHP | 8.1.13 |
Python | 3.10.8 |
Database | MariaDB 10.5.16-MariaDB-1:10.5.16+maria~focal |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
[OK]
[OK] MySQl and PHP time match
[OK] Redis is functional
Hi
I can no longer see my Cisco devices BGP neighbours.
I am using IOS XE Bengaluru & Gibraltar primarily.
I upgraded my LibreNMS server from 22.8 to 22.11 and can no longer see my BGP neighbours. The OSPF neighbours still show however.
Is there something that needs to be enabled on the newer version of LibreNMS to allow the neighbours to show?
./discover.php -h HOSTNAME -d -v -m bgp-peers and ./poller.php -h HOSTNAME -d -v -m bgp-peers output
