@Dear Pipo:
From the ui , I got:
Draw error , on prefix and nan on ipv4unicast.
After a little investigation on the mysql table , I can confirm that bgpPeers_cbgp is empty.
And finally , after analize the discovery.php output I can see:
The corresponding mysql inserts statements per bgp peer:
SQL[INSERT IGNORE INTO bgpPeers_cbgp (device_id,bgpPeerIdentifier,afi,safi,context_name,AcceptedPrefixes,DeniedPrefixes,PrefixAdminLimit,PrefixThreshold,PrefixClearThreshold,AdvertisedPrefixes,SuppressedPrefixes,WithdrawnPrefixes,AcceptedPrefixes_delta,AcceptedPrefixes_prev,DeniedPrefixes_delta,DeniedPrefixes_prev,AdvertisedPrefixes_delta,AdvertisedPrefixes_prev,SuppressedPrefixes_delta,SuppressedPrefixes_prev,WithdrawnPrefixes_delta,WithdrawnPrefixes_prev) VALUES (:device_id,:bgpPeerIdentifier,:afi,:safi,:context_name,:AcceptedPrefixes,:DeniedPrefixes,:PrefixAdminLimit,:PrefixThreshold,:PrefixClearThreshold,:AdvertisedPrefixes,:SuppressedPrefixes,:WithdrawnPrefixes,:AcceptedPrefixes_delta,:AcceptedPrefixes_prev,:DeniedPrefixes_delta,:DeniedPrefixes_prev,:AdvertisedPrefixes_delta,:AdvertisedPrefixes_prev,:SuppressedPrefixes_delta,:SuppressedPrefixes_prev,:WithdrawnPrefixes_delta,:WithdrawnPrefixes_prev) {"device_id":47,"bgpPeerIdentifier":"204.199.0.169","afi":"ipv4","safi":"unicast","context_name":"","AcceptedPrefixes":0,"DeniedPrefixes":0,"PrefixAdminLimit":0,"PrefixThreshold":0,"PrefixClearThreshold":0,"AdvertisedPrefixes":0,"SuppressedPrefixes":0,"WithdrawnPrefixes":0,"AcceptedPrefixes_delta":0,"AcceptedPrefixes_prev":0,"DeniedPrefixes_delta":0,"DeniedPrefixes_prev":0,"AdvertisedPrefixes_delta":0,"AdvertisedPrefixes_prev":0,"SuppressedPrefixes_delta":0,"SuppressedPrefixes_prev":0,"WithdrawnPrefixes_delta":0,"WithdrawnPrefixes_prev":0} 1.4ms]
And … at the end:
A delete for every insert …
SQL[DELETE FROM bgpPeers_cbgpWHEREdevice_id=? AND bgpPeerIdentifier=? AND context_name=? AND afi=? AND safi=? [47,"204.199.0.169","","ipv4","unicast"] 0.92ms]
I think … here could be the problem … why is it deleting all rows ?
Thanks.
