Hi all,
I’m having a strange issue with one port on a Cisco Nexus 7706, N77-F348XP-23 linecard. It is alarming for low bias current, however it appears that LibreNMS is misreading the bias current limits for this particular port (and this particular port only, all other ports on the linecard it’s reading correctly). It seems to be taking the high alarm as the low limit.
Screenshot:
From the switch:
# show int e1/22 transceiver details
Ethernet1/22
transceiver is present
type is 10Gbase-SR
name is OEM
part number is SFP-10G-SR
revision is
serial number is 202212051370
nominal bitrate is 10300 MBit/sec
Link length supported for 50/125um OM2 fiber is 82 m
Link length supported for 50/125um OM3 fiber is 300 m
cisco id is 3
cisco extended id number is 4
cisco part number is 10-2415-02
cisco product id is SFP-10G-SR
cisco vendor id is V02
number of lanes 1
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 41.25 C 95.00 C -50.00 C 85.00 C -40.00 C
Voltage 3.38 V 3.59 V 3.00 V 3.50 V 3.09 V
Current 6.76 mA 15.00 mA 0.00 mA 12.00 mA 0.00 mA
Tx Power -1.66 dBm 3.00 dBm -9.29 dBm 2.00 dBm -7.30 dBm
Rx Power -2.18 dBm 3.00 dBm -13.09 dBm 2.00 dBm -11.10 dBm
Transmit Fault Count = 0
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
Here’s my validate.php output: -bash-4.2$ ./validate.php===========================================Componen - Pastebin.com
I have manually updated the threshold values so that it doesn’t alarm, however I am curious as to where LibreNMS is getting those values. If I do a “reset” for the port to go back to default, it immediately alarms again.
Any help is greatly appreciated!
