Output of validate.php
/opt/librenms # ./validate.php
Component | Version |
LibreNMS | 1.62.2 |
DB Schema | 2020_03_24_0844_add_primary_key_to_device_graphs (160) |
PHP | 7.3.14 |
MySQL | 5.7.29-32 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
(/usr/sbin/fping: can’t create socket (must run as root?))
[FAIL] fping6 should have CAP_NET_RAW!
setcap cap_net_raw+ep /usr/sbin/fping6
I’m in the process of setting up LibreNMS / Graphite / Grafana, and got the LibreNMS -> Graphite connection working yesterday, but I am seeing these lines every so often in the Graphite logs.
https://p.libren.ms/view/74b3c5cc
It looks like LibreNMS is sending a U instead of a numeric value to Graphite?
The netstats/snmp graphs in the LibreNMS web ui seems to contain numeric values, at least somethings being graphed.
