- The output of
./validate.php
If it’s an issue with the WebUI then please consider including the browser version you are using.
It is noticed that some Netapp storage volumes are reporting incorrect numbers on librenms. the snmp reporting data is correct. However, after poller calculation librenms somehow got it incorrectly.
here is the full capture of poller.
For example, volume /vol/backup data from snmp shows percentage 98% and 240008568KB(about 229GB)
available:
[37] => Array
[dfIndex] => 37
[dfFileSys] => /vol/backup/
[dfKBytesTotal] => 1395864372
[dfKBytesUsed] => 1155855800
[dfKBytesAvail] => 240008568
[dfPerCentKBytesCapacity] => 98
[dfInodesUsed] => 44728609
[dfInodesFree] => 355271386
[dfPerCentInodeCapacity] => 11
[dfMountedOn] => /vol/backup/
[dfMaxFilesAvail] => 399999994
[dfMaxFilesUsed] => 44728604
[dfMaxFilesPossible] => 2040109444
[dfHighTotalKBytes] => 3
[dfLowTotalKBytes] => 1395864372
[dfHighUsedKBytes] => 3
[dfLowUsedKBytes] => 483873332
[dfHighAvailKBytes] => 0
[dfLowAvailKBytes] => 240007824
[dfStatus] => mounted
[dfMirrorStatus] => invalid
[dfPlexCount] => 0
[dfType] => flexibleVolume
[dfHighSisSharedKBytes] => 0
[dfLowSisSharedKBytes] => -1275712872
[dfHighSisSavedKBytes] => 1
[dfLowSisSavedKBytes] => -165884876
[dfPerCentSaved] => 39
[df64TotalKBytes] => 14280766260
[df64UsedKBytes] => 13368778956
[df64AvailKBytes] => 240013356
[df64SisSharedKBytes] => 3019254360
[df64SisSavedKBytes] => 8423974420
[df64CompressSaved] => 0
[dfCompressSavedPercent] => 0
[df64DedupeSaved] => 8423894348
[dfDedupeSavedPercent] => 39
[df64TotalSaved] => 8423843328
[dfTotalSavedPercent] => 39
[df64TotalReservedKBytes] => 0
However, poller reports storage_perc 94% and storage_free is 934600544256 (about 870GB)
Storage /vol/backup/: netapp-storage
Array
[storage_id] => 251
[device_id] => 60
[storage_mib] => netapp-storage
[storage_index] => 37
[storage_type] => flexibleVolume
[storage_descr] => /vol/backup/
[storage_size] => 14623504650240
[storage_units] => 1024
[storage_used] => 13688904105984
[storage_free] => 934600544256
[storage_perc] => 94
[storage_perc_warn] => 60
[storage_deleted] => 0
[units] => 1024
[used] => 13689629650944
[size] => 14623504650240
[free] => 933874999296
The output of ./validate.php
librenms]# ./validate.php
LibreNMS | 1.40
DB Schema | 251
PHP | 7.0.30
MySQL | 5.5.56-MariaDB
RRDTool | 1.6.0
SNMP | NET-SNMP 5.7.2
[OK] Composer Version: 1.6.5
Thanks,
Roger
