I think, this is a bug:
on a device page -> got to tap “Logs” -> select type “trap” -> hit “Filter”
This shows all eventlog entries by the type “trap”, but from all devices.
./validate.php
| LibreNMS | 1.43-119-g6242f941f |
| DB Schema | 268 |
| PHP | 7.0.32 |
| MySQL | 10.0.35-MariaDB |
| RRDTool | 1.4.7 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.2
[FAIL] fping6 could not be executed. fping6 must have CAP_NET_RAW capability (getcap) or suid. Selinux exlusions may be required.
(bash: /usr/sbin/fping6: Keine Berechtigung)
[FAIL] fping6 should be suid!
[FIX] chmod u+s /usr/sbin/fping6
[FIX] sudo chown -R librenms:librenms /opt/librenms
Files:
/opt/librenms/storage/framework/views/c7a505896e629393a98836fa4a4077a7
