The ./scripts/test-template.php is not working anymore. It seems that this issue may be linked to the Laravel code merged for alerting recently.
https://p.libren.ms/view/93042510
It is reproducible with any combination of template_id, rule_id and device_id so it is probably a general issue.
What kind of test should I do to help ?
librenms@host:~$ ./validate.php
| Component |
Version |
| LibreNMS |
1.41-24-gad6ec7f72 |
| DB Schema |
254 |
| PHP |
7.0.30-0+deb9u1 |
| MySQL |
10.1.26-MariaDB-0+deb9u1 |
| RRDTool |
1.6.0 |
| SNMP |
NET-SNMP 5.7.3 |
[OK] Composer Version: 1.6.2
Looks like the exception source is in this code in file ./LibreNMS/Alert/Template.php, called from ./includes/alerts.inc.php:
class Template
public $template;
public function getTemplate($obj = null)
d_echo($obj);
if ($this->template) {
// Return the cached template information.
return $this->template;
// Generate Exception
$this->template = AlertTemplate::whereHas(‘map’, function ($query) use ($obj) {
$query->where(‘alert_rule_id’, ‘=’, $obj[‘rule_id’]);
})->first();
// End Generate Exception
Hello
I have no idea of the fix. Still trying to understand what’s going on. The best I have done so far is to identify the piece of code up to which the function executes correctly. But I have no clue what this code is doing after…
If somebody who understands this code can try to have a look …
Bye
PipoCanaja
What does test-template.php do?
It allows to generate in the CLI the text of an alert/alert_rule/template, during the troubleshooting of the template writing.
With the new syntax, it’s a good way to check if something is broken before missing a mail
PipoCanaja
Seems very similar to test-alert.php
Does more or less the same, but in CLI instead of using the transport. (and spaming my colleagues in my case
Seems that I get it.
Need to cleanup the code but should come with a PR.
