Please confirm each of the sections below by putting an x in the box like [x].
[ x] Is your install up to date? Updating your install
Please do not submit an issue if your install is not up to date within the last 24 hours or on a stable monthly release.
[x ] Please include all of the information between the ==================================== section of ./validate.php which you can run from the cli.
Component
Version
LibreNMS
1.30-68-gf3d7a44
DB Schema
203
PHP
5.4.16
MySQL
5.5.52-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
Please provide ALL info asked for here.
[ x] Please provide as much detail as possible.
suddently the akcp device not work -> it is not possible to open devices wthin librenms web interface
I need to delete the akcp devices -> the devices have 511152 Interfaces seen after delete in cmd line :
Yes sure ! After i use the delete.php script i see that 511152 interfaces were deleted ! the 2nd akcp had also this high amount of interfaces ! on the web interface i doesn’ t see this interfaces !
