Bulk Updating Device Locations - Overwritten by SNMP
I’m facing an issue where device locations set in the MariaDB database are being overwritten by SNMP data. I have over 500 devices, and it’s not feasible to manually adjust the sysLocation on each device.
Here’s the situation:
I have updated the locations in my MariaDB database, but they are being overwritten after a short time.
I suspect this is happening because LibreNMS is pulling location information from SNMP.
Is there a way to disable SNMP location updates or give priority to the database?
In addition to manually updating sysLocation, you have to enable the device attrib that blocks the poller from updating it. Try setting it from the web ui and check what it sets to see.
