Validate Results:
./validate.php
Component | Version |
LibreNMS | 1.48.1-25-g21192a9cf |
DB Schema | 2019_01_16_195644_add_vrf_id_and_bgpLocalAs (131) |
PHP | 7.0.33-0+deb9u1 |
MySQL | 10.1.37-MariaDB-0+deb9u1 |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.4
[WARN] Your install is over 24 hours out of date, last update: Fri, 08 Feb 2019 14:17:29 +0000
[WARN] You are on the PHP 5.6/7.0 support branch, this will prevent automatic updates.
Update to PHP 7.1.3 or newer (PHP 7.2 recommended) to continue to receive updates.
[FAIL] You need to run this script as root or librenms
pi@netops:/opt/librenms $
I only have two devices that I am currently monitoring.
A Cisco C3500XL switch and an HP ProCurve Switch.
The HP ProCurve Switch behaves as expected, showing Traffic Graphs. The Cisco polls, shows the ports, but no graphs, no traffic data.
Ideas?
