Calix B6 (Occam) platform ethernet ports not being discovered correctly
We use the Calix B6 platform in our shop. I have set up all of the devices on LibreNMS. While some of the metrics (processor etc) are showing up. I am having trouble especially with the ports being discovered correctly.
I was wondering if someone could help us through the process of getting ports to map correctly. I am a newbie so I will probably require some hand holding, but I am willing!
I did a validate.php and everything seems in line.
Here is the output for ./discovery.php -h HOSTNAME -d | ./pbin.sh
https://p.libren.ms/view/ef730b95
Here is the output for ./poller.php -h HOSTNAME -r -f -d | ./pbin.sh
https://p.libren.ms/view/bceb8741
Any and all help would be much appreciated, please let me know what else I can provide!
Thank you,
bwehrspann
I thought I might give a little more detail on this post in an effort to clarify the problem.
“I am having trouble especially with the ports being discovered correctly.”
To give a little more detail to this post, the ports are not returning utilization on many of the port graphs.
