All of a sudden i encoutered this issue:
Call to a member function firstWhere() on null {“exception”:"[object] (Symfony\Component\Debug\Exception\FatalThrowableError(code: 0): Call to a member function firstWhere() on null at /home/librenms/LibreNMS/OS/Timos.php:674)"}
Device hasnt been polled for over an hour. I have several more devices of exact same type and everything is fine with them.
Does anybody know what reason for this could be?
I had to run rediscover to make it work again which is totally fine. If things like this happen, where you get a warning about devices not being polled, would this be recommended action or is it better to wait it out? I mean will system solve this on its own eventually?
This issue keeps coming back. Right now i have two devices that haven’t been polled for over 3 days. It’s usually cleared after next discovery but not this time. I have plenty of devices of same type and they are working fine.
this time it is different line in code. Maybe code changed over time. Call to a member function firstWhere() on null {"exception":"[object] (Error(code: 0): Call to a member function firstWhere() on null at /home/librenms/LibreNMS/OS/Timos.php:804)"}
After some investigation i think the problem is that this function cannot handle null/empty value returned from poller.
Issue is with Nokia devices and MPLS LSP polling. Device in question doesnt have any LSP defined and returns null which causes function to fail.
