Call to undefined method Illuminate
Just did a git pull and now I’m getting the following when trying to open a device. Not sure how to troubleshoot this. OS is up to date with packages.
[2022-02-13T19:07:47.757286-05:00] production.ERROR: Call to undefined method Illuminate\View\Compilers\BladeCompiler::render() {“userId”:8,“exception”:“[object] (Error(code: 0): Call to undefined method Illuminate\View\Compilers\BladeCompiler::render() at /opt/librenms/vendor/laravel/framework/src/Illuminate/Support/Facades/Facade.php:261)”}
validate.php is fine:
LibreNMS 22.1.0-69-g4c9d4eefd
DB Schema 2021_12_02_113537_ports_stp_designated_cost_change_to_int (234)
PHP 7.4.3
Python 3.8.10
MySQL 10.3.32-MariaDB-0ubuntu0.20.04.1
SNMP 5.8
[OK] Composer Version: 2.2.6
I’m using Ubuntu LTS
Distributor ID: Ubuntu
Description: Ubuntu 20.04.3 LTS
Release: 20.04
Codename: focal
git pull is not how you update librenms, Updating - LibreNMS Docs
I’m using the section for Advanced Users. We can’t upgrade daily as this is a production system and in the past daily upgrades have caused issues. I’ve been following that method for sometime now without issues for the most part.
I see.
Make sure you still run daily.sh in cron like it says tho, it does a lot of other things.
The error suggests you didn’t run the ./scripts/composer_wrapper.php install --no-dev step
Thanks for the help, that was the issue…I must have missed that step…guess that happens when your doing the upgrade during a 3AM maintenance window :crazy_face:
