Can not get proper current value for restablished alarm rule
Hi guys.
I successfully created an alert rule for my apc ups.
I can generate an alarm when runtime falls under 30min.
Problem is that when runtime is restablished can not properly get current value to print on the template:
Take a look to test-template.php output.
[[email protected]_wiber scripts]#  php test-template.php  -t14 -r23   -h 172.30.18.200
Array
    [hostname] => 172.30.18.200
    [sysName] => ups_bv
    [sysDescr] => APC Web/SNMP Management Card (MB:v3.9.2 PF:v3.6.1 PN:apc_hw02_aos_361.bin AF1:v3.5.8 AN1:apc_hw02_sumx_358.bin MN:AP9619 HR:A10 SN: BA0930027668 MD:07/25/2009) (Embedded PowerNet SNMP Agent SW v2.2 compatible)
    [sysContact] => Unknown
    [os] => apc
    [type] => power
    [ip] =>
    [hardware] => Smart-UPS 750 651.18.I
    [version] => AOS v3.6.1 / App v3.5.8
    [serial] =>
    [features] =>
    [location] => LUJAN_BV
    [uptime] => 4142955
    [uptime_short] =>  47d 22h 49m 15s
    [uptime_long] =>  47 days 22 hours 49 minutes 15 seconds
    [description] =>
    [notes] =>
    [alert_notes] =>
    [device_id] => 28
    [rule_id] => 23
    [id] => 3680
    [proc] =>
    [status] => 1
    [status_reason] =>
    [ping_timestamp] =>
    [ping_loss] => 0
    [ping_min] => 3.99
    [ping_max] => 6.09
    [ping_avg] => 4.73
    [debug] => Array
    [title] => LIBRENMS: ALERTAS DE TIEMPO DE UPS REESTABLECIDAS ✅
    [elapsed] => 14m 55s
    [faults] => Array
            [1] => Array
                    [device_id] => 28
                    [inserted] => 2020-09-30 14:19:50
                    [sysName] => ups_bv
                    [ip] =>
                    [overwrite_ip] =>
                    [community] => public
                    [authlevel] =>
                    [authname] =>
                    [authpass] =>
                    [authalgo] =>
                    [cryptopass] =>
                    [cryptoalgo] =>
                    [snmpver] => v1
                    [port] => 161
                    [transport] => udp
                    [timeout] =>
                    [retries] =>
                    [snmp_disable] => 0
                    [bgpLocalAs] =>
                    [sysObjectID] => .1.3.6.1.4.1.318.1.3.2.7
                    [features] =>
                    [location_id] => 12
                    [os] => apc
                    [status] => 1
                    [status_reason] =>
                    [ignore] => 0
                    [disabled] => 0
                    [uptime] => 4141454
                    [agent_uptime] => 0
                    [last_polled] => 2020-11-17 12:35:10
                    [last_poll_attempted] =>
                    [last_polled_timetaken] => 6.67
                    [last_discovered_timetaken] => 20.34
                    [last_discovered] => 2020-11-17 06:38:01
                    [last_ping] => 2020-11-17 12:35:10
                    [last_ping_timetaken] => 6.86
                    [purpose] =>
                    [type] => power
                    [serial] => AS0945141318
                    [icon] => apc.svg
                    [poller_group] => 0
                    [override_sysLocation] => 0
                    [notes] =>
                    [port_association_mode] => 1
                    [max_depth] => 0
                    [disable_notify] => 0
                    [sensor_id] => 1069
                    [sensor_deleted] => 0
                    [sensor_class] => runtime
                    [poller_type] => snmp
                    [sensor_oid] => .1.3.6.1.4.1.318.1.1.1.2.2.3.0
                    [sensor_index] => upsAdvBatteryRunTimeRemaining.0
                    [sensor_type] => apc
                    [sensor_descr] => Runtime
                    [group] =>
                    [sensor_divisor] => 6000
                    [sensor_multiplier] => 1
                    [sensor_current] => 24          <<=======this is not ok
                    [sensor_limit] => 3000
                    [sensor_limit_warn] => 2000
                    [sensor_limit_low] => 30
                    [sensor_limit_low_warn] => 60
                    [sensor_alert] => 1
                    [sensor_custom] => No
                    [entPhysicalIndex] =>
                    [entPhysicalIndex_measured] =>
                    [lastupdate] => 2020-11-17 12:35:05
                    [sensor_prev] => 26
                    [user_func] =>
                    [string] => sysObjectID => .1.3.6.1.4.1.318.1.3.2.7; sysDescr => APC Web/SNMP Management Card (MB:v3.9.2 PF:v3.6.1 PN:apc_hw02_aos_361.bin AF1:v3.5.8 AN1:apc_hw02_sumx_358.bin MN:AP9619 HR:A10 SN: BA0930027668 MD:07/25/2009) (Embedded PowerNet SNMP Agent SW v2.2 compatible); location_id => 12; sensor_id => 1069; sensor_oid => .1.3.6.1.4.1.318.1.1.1.2.2.3.0; sensor_descr => Runtime;
    [builder] => {"condition":"AND","rules":[{"id":"sensors.sensor_current","field":"sensors.sensor_current","type":"string","input":"text","operator":"less_or_equal","value":"`sensors.sensor_limit_low`"},{"id":"sensors.sensor_alert","field":"sensors.sensor_alert","type":"string","input":"text","operator":"equal","value":"1"},{"id":"macros.device_up","field":"macros.device_up","type":"integer","input":"radio","operator":"equal","value":"1"},{"id":"sensors.sensor_class","field":"sensors.sensor_class","type":"string","input":"text","operator":"equal","value":"runtime"}],"valid":true}
    [uid] => 3682
    [alert_id] => 318
    [severity] => warning
    [rule] =>
    [name] => tecnet_ups_apc_runtime
    [timestamp] => 2020-11-17 12:40:12
    [contacts] => Array
    [state] => 0                              <==============as you can see alarm is clear now
    [alerted] => 0
    [msg] => LIBRENMS: ALERTAS DE TIEMPO DE UPS REESTABLECIDAS ✅
Rule: tecnet_ups_apc_runtime
Time elapsed: 14m 55s
Timestamp: 2020-11-17 12:40:12
Unique-ID: 3682
Faults:
1:
Severidad: warning
Nodo: ups_bv
Sensor: Runtime
Valor minimo: 30 se ha restablecido
As you can see alarm si clear , runtime value is 54 minutes now but current value for the template is still 24.
Any ideas ?
Can not imagine where can I get proper value.
Leandro.
