I have a Cisco switch at the edge of the network in our data center. It has two links each to two different ISPs.
If I use:
interface G1/0/1
desc Cust: Verizon (link 1)
interface G2/0/1
desc Cust: Verison (link 2)
interface G1/0/2
desc Cust: ATT (link 1)
interface G2/0/2
desc Cust: ATT (link 2)
Then when it does graphs it gives me composite graphs for each of the ISPs.
If I use “Transit” in the descriptions, it sums up all 4 interfaces.
Peering seems to work like Transit.
What should I be using? ATT & Verizon are not customers, they are ISPs. But Customers sums them the way I want. What controls whether there are subtotals or only totals?
I’m not following you. I created two ports, both called Transit, one named Cogent, the other Level3. I can see the summary of both together and the individual ones under the ‘Transit’ link in the ports menu
