Cannot load Poller Performance graphs
Good day.
I have 1 web server, 1 db server, 1 rrd storage machine and few poller machines.
I use remote rrdcached. All graphs works fine, but…
when I open the page https://librenms/poller/performance I see: in section “Total Poller Time” all graphs load for a veeery long time, in section “Total Poller Time Per Module” the graphs cannot load at all. I I browser debug tool I see 504 gateway timeout. I open a separate link to the graph, for example, https://librenms/graph.php?type=global_poller_modules_perf&legend=no&from=1526983800&to=1590055800&height=60&width=113 and I see 504 error again.
In shell at this time I see next:
service php-fpm status
Redirecting to /bin/systemctl status php-fpm.service
● php-fpm.service - The PHP FastCGI Process Manager
Loaded: loaded (/usr/lib/systemd/system/php-fpm.service; enabled; vendor preset: disabled)
Active: active (running) since Чт 2020-05-21 12:59:40 EEST; 13min ago
Main PID: 26510 (php-fpm)
Status: “Processes active: 7, idle: 18, Requests: 85, slow: 0, Traffic: 1.3req/sec”
CGroup: /system.slice/php-fpm.service
├─26510 php-fpm: master process (/etc/php-fpm.conf)
├─26511 php-fpm: pool www
├─26512 php-fpm: pool www
├─26513 php-fpm: pool www
├─26514 php-fpm: pool www
├─26515 php-fpm: pool www
├─26527 php-fpm: pool www
├─26573 php-fpm: pool www
├─26592 php-fpm: pool www
├─26593 php-fpm: pool www
├─26594 php-fpm: pool www
├─26595 php-fpm: pool www
├─26649 php-fpm: pool www
├─26662 php-fpm: pool www
├─26663 php-fpm: pool www
├─26664 php-fpm: pool www
├─26714 php-fpm: pool www
├─26741 php-fpm: pool www
├─26742 php-fpm: pool www
├─26873 php-fpm: pool www
├─26900 php-fpm: pool www
├─26901 php-fpm: pool www
├─26968 php-fpm: pool www
├─26979 php-fpm: pool www
├─26995 php-fpm: pool www
├─26996 php-fpm: pool www
├─27107 /usr/bin/rrdtool -
├─27108 /usr/bin/rrdtool -
├─27109 /usr/bin/rrdtool -
├─27110 /usr/bin/rrdtool -
├─27111 /usr/bin/rrdtool -
├─27112 /usr/bin/rrdtool -
├─27113 /usr/bin/rrdtool -
├─27114 /usr/bin/rrdtool -
├─27115 /usr/bin/rrdtool -
├─27116 /usr/bin/rrdtool -
├─27118 /usr/bin/rrdtool -
├─27119 /usr/bin/rrdtool -
├─27132 /usr/bin/rrdtool -
└─27133 /usr/bin/rrdtool -
май 21 12:59:39 librenms.tenet.ua systemd[1]: Starting The PHP FastCGI Process Manager…
май 21 12:59:40 librenms.tenet.ua systemd[1]: Started The PHP FastCGI Process Manager.
and
ps ax|grep rrdtool
27107 ? R 0:05 /usr/bin/rrdtool -
27108 ? S 0:00 /usr/bin/rrdtool -
27109 ? R 0:05 /usr/bin/rrdtool -
27110 ? S 0:00 /usr/bin/rrdtool -
27111 ? R 0:05 /usr/bin/rrdtool -
27112 ? R 0:05 /usr/bin/rrdtool -
27113 ? S 0:00 /usr/bin/rrdtool -
27114 ? S 0:00 /usr/bin/rrdtool -
27115 ? R 0:05 /usr/bin/rrdtool -
27116 ? S 0:00 /usr/bin/rrdtool -
27118 ? R 0:05 /usr/bin/rrdtool -
27119 ? S 0:00 /usr/bin/rrdtool -
27132 ? S 0:03 /usr/bin/rrdtool -
27133 ? S 0:00 /usr/bin/rrdtool -
27198 pts/2 S+ 0:00 grep --color=auto rrdtool
I don’t know what’s going on and how fix it. Please help.
LibreNMS 1.63-108-g77b87cb
DB Schema 2020_04_19_010532_eventlog_sensor_reference_cleanup (164)
PHP 7.3.17
Python 3.6.8
MySQL 5.5.65-MariaDB
RRDTool 1.7.1
SNMP NET-SNMP 5.7.2
[OK] Composer Version: 1.10.6
the question is still relevant. if someone can help - please.
Just wanted to post here and say I am having this same issue with my Total Poller Time Per Module graphs. I get broken images and when I click on them I get Gateway Timeouts.
Since this thread is over a year old. I figured I’d ask you to see if you ever resolved your issue and if so. How did you resolve it? If it’s still an issue, hopefully someone sees this and has a clue.
getting the same recently… anyone?
If you have a lot of devices then trying to build the graph can take a long time and like you’re most likely seeing, lead to timeouts and the graph failing.
is there a workaround for this? i see the io ops going up markedly when this tries to generate. what is the actually process to build these particular graphs, is it reading ALL rrds file for each device? can this be optimised. timeouts adjusted?
It only reads one rrd per device I think so you can increase your timeouts but in all honesty you’re just kicking the can down the road. As is, I don’t think anything else can be done.
so what you are inferring is more resource required for the libre instance? always used to load , but i guess has reached critical mass.
