Hi expert / all,
I’m facing error as per snapshot. Appreciate any feedback how to solve it. Thanks
Hi expert / all,
Your web server is running as the wrong user, run validate and see what it brings back, I expect it will flag the user as being set wrong. The install docs cover the setup of your web server so it’s probably worth going over them.
Below is the output. Is there any issue on below output?
Component | Version |
LibreNMS | 24.11.0-42-g496bb7f08a (2024-12-04T08:07:05+00:00) |
DB Schema | 2024_11_22_135845_alert_log_refactor_indexes (308) |
PHP | 8.3.14 |
Python | 3.10.12 |
Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 |
RRDTool | 1.7.2 |
SNMP | 5.9.1 |
[OK] Composer Version: 2.8.3
You need to run validate in the WebUI
Check your developer console then when you run the poller process in the webui
