I want to set snmp.max_oid config globally, but cannot find the config parameter.
The config parameter is referenced here .
The output of lnms command:
bash-5.1# lnms config:set snmp.max_oid 50
This is not a valid setting. Please check your input
Is the config parameter deprecated?
