Can't add Devices in web
Hi ,
I imported LibreNMS through VM ova, and when I opened the web, I found that I couldn’t add a device from the “Devices” menu.
how to fix that?
LibreNMS 23.11.0 (2023-11-17T10:57:41+08:00)
DB Schema 2023_11_04_125846_packages_increase_name_column_length (273)
PHP 8.1.2-1ubuntu2.14
Python 3.10.12
Database MariaDB 10.6.12-MariaDB-0ubuntu0.22.04.1
SNMP 5.9.1
[OK] Composer Version: 2.6.5
[OK] MySQl and PHP time match
Your user probably needs to have the ‘admin’ role assigned.
Click on your user and settings and check ‘Device Permissions’ – probably needs to be ‘Global Administrative Access’ …
$ lnms user:add --help
Description:
  Add a local user, you can only log in with this user if auth is set to mysql
Usage:
  user:add [options] [--] <username>
Arguments:
  username                   The username the user will log in with
Options:
  -p, --password=PASSWORD    Password for the user, if not given, you will be prompted
  -r, --role=ROLE            Set the user to the desired role [user, global-read, admin] [default: ["user"]] (multiple values allowed)
ie create a user with —role=admin
